New U7194
bbehle
New U7194
Post by bbehle »
Just purchased a U7194 and now im wondering what I got myself into. Do the programmers come with the serial cable and dc power cord or do I have to buy that seperate? Where? Also will I need to download the current updates before installing the unit? I have read about the Torque Management and also the V4 an V8 modes being an issue so im wondering if I will have the latest and greatest version. I would be willing to have a custom tune performed if it will help eliminate some issues. Thanks in advance.
johan
RE: New U7194
Post by johan »
All the updates for this part number is on this page, http://www.diablosport.com/index.php?mo ... lay&pid=88
The programmer does not come with the cords or power supply, the downloads page shows what you need with radio shack part numbers included.
Johan< @ >DiabloSport.com
Diablosport INC
Research & Development
bbehle
cords and interface
Post by bbehle »
I went to the downloads page but cant findanything that tells me what cords. Excuse my ignorance but I need a little more guidance. Also how do you save the program so you can read it and also send it? Please be patient with me as I want to get this done right. Thanks, Brian
RE: cords and interface
1: Serial Cable:
Standard straight-through DB9 (9-pin to 9-pin) RS232C serial cable (6 foot cable is more than enough). Check your computer to see if you have a male or a female port on the back, as some are different. You will need a male end to go into your Predator.
(Radio Shack Part # 26-117, 6-ft DB9 male to DB9 female shielded cable.)
2: Power Adapter:
CLASS 2 TRANSFORMER
OUTPUT : 12VDC 1000mA (1 Amp)(Radio Shack Part # 273-1776)
Note: Plug Tip is 2.5mm x 5.5mm, female, and center is positive.(Radio Shack Part # 273-1717)
