AFR with procharger
uky2000
AFR with procharger
Post by uky2000 »
hi i have 05 mustang gt with P-1SC-1 procharger ,long tube headers and cat back + i have perdator with procharger custom tune it comes with the procharger
i have problem with the fuel @ wot it's too lean i want to known the AFR @wot so i can adjust the fuel table
i can't reach 10psi only 8psi
yukon denali 6.2 with k&n air intake sys+corsa exhaust sys+diablo tune
08 Corvette zo6 with k&n cai+corsa exhaust sys+diablo tune
09 mustang gt waiting for predator
sohfast94
RE: AFR with procharger
Post by sohfast94 »
Did you put it on a dyno? Or do you have a wideband in the car? IF you could make me a datalog of advanced WOT until it leans out I'm sure I could troublshoot it for you... What's your setup? Doesn't the procharger only come with 8psi? You have a stock MAF?
Insert Clever comment here...
uky2000
Post by uky2000 »
ok man i will send my dyno sheet tomorrow with the wot log
uky2000
Post by uky2000 »
that's my dyno chart man sorry for delay
mustang dyno.jpg (27.9 KiB) Viewed 3719 times
sohfast94
Post by sohfast94 »
I still need the log...
What is the dotted red line in the A/F chart?
tuningss
Post by tuningss »
mikel wrote:What is the dotted red line in the A/F chart?
Looks like they have it at 12:1 so it's definetly lean.
http://www.tpctuning.com
Looks like they have it at 12:1 so it's definitely lean.
Yeah, it looks like the reference line is 12:1, so it is actually running like 12.5:1....SCARY.
I'd suggest not going WOT till you get this sorted out.
Mike
uky2000
Post by uky2000 »
sorry guys for delay cause i had an accident that's my wot log
sohfast94
Post by sohfast94 »
Now if oyu send me your last tune written I'll adjust it for you.
uky2000
Post by uky2000 »
ok man just give me 10 mins
uky2000
Post by uky2000 »
that's my tune man
procharger tune.frg
(6.25 KiB) Downloaded 178 times
sohfast94
There you go...
Post by sohfast94 »
Should be right at 11.9-12.0 now...
procharger_tune_2.frg
(960.14 KiB) Downloaded 202 times
uky2000
RE: There you go...
Post by uky2000 »
thanks man i'll try it and i'll let u know
Return to “Predator Ford Gas”
