Won’t unlock Tcm and ecu
Everything is updated but still won’t tune I bought the i3 for 2017+ for Gm but it won’t work so I need to buy the 900 kit or what do I need to do it’s updated
Re: Won’t unlock Tcm and ecu
what vehicle are you trying to tune specifically?
and what device are you using?
DrummerRacing
Hey all, I have an I3 and have used it for quite sometime on my 04 Z06 corvette with great
results and just a few days ago i got it out and updated it and now it won't let me do anything
but install the stock saved tune, any of the 93,91,diablo tune it says reduced power on the
digital display of the car and wont start ,so I put the stock tune back in it and it runs...
just wanted to know if something can be done about the current I3 I have or do i need to
start over with a new one???? thanks
nothing changed on the car, you just updated the device and this is happening?
are there any codes when the tune is loaded?
DrummerRacing
yessir thats correct...i have a tech looking at it ive been talking to Mikey and
the higher up department is looking into it to see what is happening...he called
back and we went thru a sequence to try it and so far all i can do is install the
original tune cant do nothing else or it wont start
DrummerRacing
Ok wanted to update anyone that has issues as I have. Previously posted my I3 wouldn’t tune my car after I updated it but before the update it worked as it should and did so very well. So after 2 months with Diablo tech working on the issue this is what fixed my issue
Make sure your update software is updated to current version. Mine however wasn’t so that was first thing
So then we tried to install tunes other than the stock tune and no matter what the car wouldn’t start. Put back to stock and no problem. Yesterday had tech helping on phone and started trying to get data from installing the tunes and changing parameters to due process of elimination and try to get it to run on something other than stock. Well about an hour into this procedure I got a low voltage reading on dash and wouldn’t even spin over. This whole time I had charger on battery to keep voltage from getting too low. Checked battery with meter and had 14.4 volts but would not start engine. So hooked up jump box and car started and ran fine. Battery was weak internally and load test showed that so replaced battery and car started and run properly. Installed Diablo tune changed my parameters like I want and all is well now. In hindsight I was not having any issues with the battery and spinning the engine over until it sat for a while doing the tests and just goes to show that you should always check your battery with load tester to rule that out. I know this is a long post but I hope it may help someone else figure out their issues. Thanks again to all the techs at Diablo sport for your help and patience.
Interesting find, thanks for sharing!
