2009 corvette support
rpman
Post by rpman »
Does anyone know if the U7194 supports the 2009 Corvette yet. I see that the update section has the 9r05a and 9r06 updates. Do these support the 09 vettes and if so what tunes are available? Thanks.
RE: 2009 corvette support
according to the application chart, yes - it does support the 09 vette...
http://diablosport.com/index.php?module ... lay&pid=83
workhorse
Post by workhorse »
I will be trying out 9r05a this weekend, so I'll post results.
rpman
Post by rpman »
Anyone tried this yet? Any issues or bugs with it?
LostAngel
Post by LostAngel »
If the tune for the '09 is anything like the '08, the only problem I, along with a couple other '08's have had is sometimes when flashing...we get a lean condition. To fix this, we just re-applied the tune.
2008 Chevrolet Corvette
Victory Red
MN6
--Mods--
Avic-D3
SLP LoudMouth I Exhaust
Vararam Intake w/ Throttle Body Spacer
Predator DiabLewTune
workhorse
Post by workhorse »
UNSUPPORTED...
no love from 9r05a.
Re: RE: 2009 corvette support
workhorse wrote:UNSUPPORTED...
no love from 9r05a.
What vehicle?
workhorse
Post by workhorse »
no love from 9r05a.
What vehicle?
2009 Corvette 2dr coupe, Z51 M6, LS3(of course)
looks like engine code 'W' from VIN. Here's the first 11 digits of VIN - 1G1YY26W995xxxxxx
rpman
RE: Re: RE: 2009 corvette support
Post by rpman »
Oh great! That is the same as mine. Is it showing up as unsupported when you connect it?
workhorse
Re: RE: Re: RE: 2009 corvette support
Post by workhorse »
rpman wrote:Oh great! That is the same as mine. Is it showing up as unsupported when you connect it?
Just about as soon as connected. Most of the first level menus work, but as soon as I select Performance Tune and it prompts for Agree/Disagree on the disclaimer(pressing Agree of course), I get the unsupported error msg.
On the bright side, its seems like the Diag menu might let me clear any codes, if I had any. Although, this is likely just due to support of the OBDII standard.
johan
RE: Re: RE: Re: RE: 2009 corvette support
Post by johan »
When you see the unsupported message does it display a calid in that same message?
Johan< @ >DiabloSport.com
Diablosport INC
Research & Development
workhorse
Re: RE: Re: RE: Re: RE: 2009 corvette support
Post by workhorse »
johan wrote:When you see the unsupported message does it display a calid in that same message?
Message reads: Unsupported Vehicle, this part number does not support your vehicle, please .....
If it's helpful, here is the CALIDs read from the diag menu:
12628990 Main OS
12629159 Speed cal
12629158 System cal
12629165 Fuel sys cal
12629155 Engine Diagnos
12629149 Engine operati
12625892 Engine cal
12629151 Slave OS
RE: Re: RE: Re: RE: Re: RE: 2009 corvette support
Ok, so....to confirm, what Johan really NEEDS to know is if the Predator displays the calid on this error message?
The ..... does not really describe the entire error message.
workhorse
Post by workhorse »
mikel wrote:Ok, so....to confirm, what Johan really NEEDS to know is if the Predator displays the calid on this error message?
No, there was not a calid displayed in the remaining part of the error message - "..... contact original reseller."
johan
Post by johan »
Ok so this is actually one of the newer "locked" gm flashes, we are working on a work around for this.
If you have a buddy that happens to work at the dealer ask him to try to reflash you with the tech2 and i bet you it will not work either, there is an error with the latest flashes from gm where the flash gets locked and nothing can program it.
Diablosport INC
