04 GTO, Predator Tuner
- oneslowGTO
I have an 04 GTO with K&N Cold Air Intake, other than that everything is stock. I'am a first time user with the tuner and need some help. What tune and modifications would you reccommend for the most noticable power?
RE: 04 GTO, Predator Tuner
Simply install the performance tune and let it rip.
If you want to get further into it, follow the stickies on how to dial in the fuel trims and enjoy.
- oneslowGTO
Thats odd...A4 or M6?
Did you have good fuel in the tank?
- oneslowGTO
Automatic (A4) or Manual (M6)?
If you had 98 octane in there, you were likely experiencing Knock which will reduce power output.
Get some good gas in there and let it rip.
- oneslowGTO
yeah, the diablo tune is made for 91/93 octane... need to run high octane, good gas in there...
mobil, exxon, sunoco, amoco or bp...
As far as you can...
- oneslowGTO
there is no 87 or 89 octane tune... those cars are meant to run on 91 octane at the lowest... you need to run 91 or 93 octane...
if you add headers, you will need to adjust parameters for the tune...
if you add CAI/exhaust, you SHOULD adjust your tune to get better performance and get your fueling dialed in correctly...
the preset tunes are based on stock vehicle setups...
- oneslowGTO
