idle is rough
idle is rough
I have an 07 Dodge 3500 with a 5.9L and I just installed a programmer in it and it is idling rough, I was wondering if this is to be expected because it stops when the stock program is put back in. On the tach it's reading about 720rpm on the performance stage and if I bring it up to 800 it levels off again.
RE: idle is rough
We are looking into this and will let you guys know if we find a fix.
RE: idle is rough
same problem...whole truck shakes at idle with extreme tune and higher.
Re: RE: idle is rough
yep same here also...not bad but shakes...cummin4U wrote:same problem...whole truck shakes at idle with extreme tune and higher.
'07 dodge megacab 4x4
5" turbo back exhaust
aem workhorse dryflow intake
pred and pucked!!!!
pred and pucked!!!!
RE: Re: RE: idle is rough
Same here. Rough idle on any tune. As soon as I "tune on the fly" to stock, idle goes back to normal.
Love the tuner. I wish it wasn't so stinking big. A monitor similar to the edge would be great. I had the edge w/ attitude monitor but it just didn't have near the power as the diablo or superchip. I ordered a quadzilla commander monitor. It has several monitoring options and will defuel, but i'd like something small to control the predator.
