2005 magnum help
obsessionz
2005 magnum help
Post by obsessionz »
installed the programmer today. the car is running really ruff at idol and at driving speeds. i re installed the original back up and the car is still running ruff. it also says injector flow problems
RE: 2005 magnum help
If it is not right with the stock tune, may need to see a dealer.
Any other codes?
obsessionz
it was running perfect before the program was installed
Try disconnecting the battery for a few minutes..
jmdi
Post by jmdi »
i had the same thing happen to me it is a mds problem go into modify tunes and shut mds off car will be fine
SRT8Tech
Post by SRT8Tech »
Its actually not an MDS problem or a Diablo problem. Its a DCX problem. Just disconnect the battery for 30 minutes and it will be fine. Unfortuneately you might have to do that everytime you load a tune. Its a flash problem with the early build 5.7L 05's. Shutting off MDS will solve the problem but if you want MDS then you are SOL and have to reset the PCM by disconnecting the battery.
2013 SuperBee......................................................
jmdi
Post by jmdi »
thanks for your input are there any fixes for this?? and does it have to be disconnected for a half hour?? i read somewhere to depress brake pedal witch will drain all the power when battery is disconnected. and if i have a tune in the car will it be earased when i do that?? thanks
SRT8Tech
Post by SRT8Tech »
There is no fix. Just have to reset the PCM. It is actually one of the steps to flash a PCM in the early builds. I found it in a TSB a while ago. You can disconnect the battery on both ends and touch the leads together to drain any voltage left in the capacitors in the PCM. That way you dont have to wait for the drain.
jmdi
Post by jmdi »
ok dont really get you on touch both ends together what you mean touch plus and minus together??
Yep. Simply put, short it out.
jmdi
Post by jmdi »
ok after i do that and reattach my cables do i have to turn wheel to right and left for abs or whatever im a ford tech but stopped in 03 so im out of date lol... thanks for help and support my name is jim thankyou alot
Quick
Post by Quick »
You'll probably have to re-calibrate your auto-up/down on the windows. Hold window button down until window hits bottom, continue to hold button for 3 seconds. Do the same for up. Then the auto up/down should work. If it works anyway no need to re-calibrate.
People say you need to re-calibrate your peddal/throttle... I kind of think that's a myth but it looks harmless enough to do it anyway. ...I forgot how. Something like turning the key to the on position and slowly pressing the throttle all the way down and back up. maybe some key on/off stuff. Somebody will chime in with the procedure.
2006 Magnum SRT8
AFE Stage II
Mopar Cat Back
185* T-stat
RDP tune by Steve
jmdi
Post by jmdi »
great thanks so much i am new to dodge and to the diablo so it is confusing at times thankyou for your support. so you have an srt8 how does it run?? that was my dream car but could only afford r/t but i love it just the same. between you and me i like dodge over ford anyday. they do run alot better
Quick
Post by Quick »
The srt8s are outstanding. It's enough power to keep you satisified on the street. It's over that threshold where you never get completely used to it -- even when you get used to it, it's enough to always puts a grin on your face. And it comes with stock handling acceptable for a road course.
2006 Magnum SRT8
AFE Stage II
Mopar Cat Back
185* T-stat
RDP tune by Steve
