Software for modify ECU firmwares from predator?
Post by 727 »
Hello. And sorry for question :)
What a program draw in picture on this page: http://diablosport.com/index.php?module ... ay&pid=118 (at the right)?
Sry for my English :) Please help :) (screen of software was attached)
RE: Software for modify ECU firmwares from predator?
that picture is of Diablosport's CMR tuning software, which is for dealers/tuners - that is the software that is used to create the tunes that are in your predator, and for creating custom tunes. It's not something that is available to you/end-users.
what software revision is your predator on?? after it boots up and is at the main menu, there's a number at the top of the screen - that is the revision number. what is it?
727
Post by 727 »
Fine :) Сan you post your cost for software? :)
We need to change the ECU Grand Cherokee SRT-8 (2008) with Predator 7135.
GS Motorsports has us ... :( We having 2 calibrations ... and those aren't work fine (((
johan
Post by johan »
You can post up your calibrations here as well as your mods list and whatever issues you have and we can check it out for you.
Johan< @ >DiabloSport.com
Diablosport INC
Research & Development
727
Re: RE: Software for modify ECU firmwares from predator?
Post by 727 »
johan wrote:You can post up your calibrations here as well as your mods list and whatever issues you have and we can check it out for you.
Thanks!
We have a kit from GSMotorsport. Those are:
1. Compressor Paxton Novi 1500 with intercooler system.
2. Forced Fuel Injectors (5 dot on injector surface) [original injector has 4 dot on surface).
3. Having two MAP Sensors. Original & Tuned. Original was display 97Kpa (+-) ... Tuned from GS = 54 Kpa (+- it taken CHECK-error by "Too low barometric pressure" ... and AT going to "safe mode").
Problem with working on idle-RPM. When easy-pressing accelerator pedal ... RPM was waving. Sometimes engine stop.
Please, sorry for my English :roll:
Here two calibration (Original + Tuned from GSMotorsport Kit):
05030376ad (Original).zip
(71.34 KiB) Downloaded 432 times
08 srt8 jeep GSM 05030376ad_dtp (GSMoto).zip
(60.48 KiB) Downloaded 443 times
RE: Re: RE: Software for modify ECU firmwares from predator?
Of course you realize that the real problem isn't the tune, its the GSM Kit. Everything they do, they do half assed. I've seen their blower kit blow numerous motors, and have seen, in person, the poor quality of their assembly work. Also, I have their heads on my motor and basically had to redo the port and polish work myself, as well as redo the valvetrain. Absolute trash. :evil:
727
Post by 727 »
I'm Agree with you :) About trash & ass))) But maybe anybody can post here your calibration file? :) Or modify upper uploaded O:-)
johan
Post by johan »
Do you know if the map sensor is from an srt4 and do you know what injectors are on it?
You are using larger injectors rather than the auxiliary ones that come with the kit originally right?
Diablosport INC
johan
Post by johan »
That file appears to be corrupted, you can e-mail me the file.
E-mail in sig below.
Diablosport INC
727
Post by 727 »
About injectors - we using injectors from Kit. There are larger than stock (original). We don't having another injectors :)) Or maybe i don't understand - what do you mean? :)
MAP sensor in GSMoto kit: CHRYSLER/DODGE SEBRING 2.4L ENG MAP SENSOR #05033224AB :( It's PORN))) We make leveling resistor (to change Omhs). It's work ... but it isn't right :(
Original (Stock): CHRYSLER# 56041018AD.
About Fuel Injectors: trying to find out this number ...
727
Re: RE: Re: RE: Software for modify ECU firmwares from preda
Post by 727 »
Found It :)
Fuel injectors from kit are: #04891574AD (Mopar).
johan
RE: Re: RE: Re: RE: Software for modify ECU firmwares from p
Post by johan »
E-mail me the files, they are corrupted in the post above.
Diablosport INC
727
Post by 727 »
Very strange ... I cant finish download file from my post.
I'll Send to you it tomorrow. Biggest thanks for answers!!!
727
Re: RE: Re: RE: Re: RE: Software for modify ECU firmwares fr
Post by 727 »
(deleted post)
johan
RE: Re: RE: Re: RE: Re: RE: Software for modify ECU firmware
Post by johan »
OK man.
Diablosport INC
Return to “General Support”
