2008 mustang diablo wont read ignition
08V6S197
Post by 08V6S197 »
ive got a 2008 mustang V6 with a BBK CAI, BBK headers, BBK 70mm TB, PYPES exhaust, and a 75shot of ZEX with a custom tune.. kinda... the diablo turns on and runs through the cycle untill i have to turn the ignition off then back on. it registers the ignition is off, and when i click ok and turn ignition on, the diablo will not register the ignition. therefore i am unable to attain my custom tune for the N2O. any suggestions?
DE07GT
RE: 2008 mustang diablo wont read ignition
Post by DE07GT »
If you call support, they'll tell you that you need to send the Predator back to them, then you need to take your car to a dealer and pay them to reflash your car back to the stock factory tune.
08V6S197
Post by 08V6S197 »
I had the car force flashed back to stock by the local ford dealership and i got a diablo swap from the diablo delaer. however it is still having the same issue.. any other suggestions?
What error message do you see?
nightrunner06
Post by nightrunner06 »
im having the same issue with my 2005 mustang v6, error message -12 i believe
08V6S197
Post by 08V6S197 »
it says did not see igntion turn on, check and make sure you do not have a performance module installed. (-10 stock tune did not store)
Return to “Predator Ford Gas”
