Chevy silverado high ltft
nineninties
Post by nineninties »
I have 2000 chevy 1500 4.8, K&n cai, single flowmaster exhuast and a predator u7198 9r15 with the 87 tune. ive been working on getting it tuned for a while now and i cant figure out what my problem is . I had a fuel indacating problem, some pinging, along with p0137 and p0157 . i did some troubleshooting and replaced the fuel pump, fuel filter, fuel regulator, pcv which corrected those problems. Im still getting high ltft's. i have a small leak after leak after the cats . could that cause it? i did some short logs due to weather. any suggestions ?
RE: Chevy silverado high ltft
wow, yeah your ltft's are pegged... definitely have leaks...
I'd also check all the clamps on your CAI, from the air filter all the way back to the throttle body, make sure everything is TIGHT...
K&N's are known for loosening up...
also, fix all of your exhaust leaks...
nineninties
Re: RE: Chevy silverado high ltft
06MonteSS wrote:wow, yeah your ltft's are pegged... definitely have leaks...
I took my truck to a muffler shop and the tech couldn't find any leaks with the exhuast the cai looks nice and tight and I'm not getting any dtc. could it be that the dealer messed with the settings because i cant find any leak
RE: Re: RE: Chevy silverado high ltft
nah... dealers can't "tune" it... they don't have the equipment to do that... all they can do is download GM programming, but they can't change anything like you can with a predator...
nineninties
Re: RE: Re: RE: Chevy silverado high ltft
06MonteSS wrote:nah... dealers can't "tune" it... they don't have the equipment to do that... all they can do is download GM programming, but they can't change anything like you can with a predator...
do you have any suggestions as to what my problem could be ? or what i could do to figure it out
Ill_Born_SS
RE: Re: RE: Re: RE: Chevy silverado high ltft
Post by Ill_Born_SS »
Can you re-log and add the 02 sensors
" Just Friggin Wicked"
Now with TCM support...
yeah, could be bad o2 senors... good call Ill....
dynometer
Post by dynometer »
is your mass air meter growing a mustache?
hahahahhaa!! another good one!
clean your MAF sensor...
http://www.crcindustries.com/auto/conte ... aspx?ID=90
nineninties
Re: RE: Re: RE: Re: RE: Chevy silverado high ltft
Ill_Born_SS wrote:Can you re-log and add the 02 sensors
here is it with the o2 sensors
Ill_Born_SS
RE: Re: RE: Re: RE: Re: RE: Chevy silverado high ltft
Is your mass air flo sensor clean? Is it stock? Is the screen in it and secure?
nineninties
Re: RE: Re: RE: Re: RE: Re: RE: Chevy silverado high ltft
Ill_Born_SS wrote:Is your mass air flo sensor clean? Is it stock? Is the screen in it and secure?
It looks alittle dirty . Yes its is the stock one and the screen is in it . the two of the three bolts that are on it were slightly loose. I think im gonna run buy auto zone tomorrow to get some cleaner and i will check the ltft's again
nineninties
RE: Re: RE: Re: RE: Re: RE: Re: RE: Chevy silverado high ltf
i cleaned the MAF sensor and its lowered the LTFT's . I lowered the fuel injector slopes -6% and its is still high
the loose bolts would be an issue too... an air leak...
gotta make sure everything is TIGHT from the air filter back through to the throttle body...
nineninties
Re: RE: Re: RE: Re: RE: Re: RE: Re: RE: Chevy silverado high
06MonteSS wrote:the loose bolts would be an issue too... an air leak...
i took it all apart and tightened everything the idle is nice and smooth and im running 89 octane
