03 silverado
jrmybck
03 silverado
Post by jrmybck »
any body have a 03 silverado that would like to share thier settings.. i am having a hard time with my injector slope setting, i also want to advance my spark at wot
jrmybck
RE: 03 silverado
Post by jrmybck »
the only time it reads 0.00 is at idle. at a steady 2000 rpm it is all over. clear up to 5.00 what is the most we can advance the timing on these.how much total timing is safe
jrmybck
RE: 03 silverado
Post by jrmybck »
i have a lift and 37'' tires, i pull a big trailor for work. i would really like to push the limits a bit.
jrmybck
RE: 03 silverado
Post by jrmybck »
can someone share there injector slope and timing settings. or is that against the rules. these 5.3 silverados are all the same.
RE: 03 silverado
no they are not the same man... hahaha... every vehicle is different and runs differently... no matter if it's the same year/make/model/engine or not... someone in the area where they live may need to adjust their fuel setting to -5%... while you, in your area and weather conditions, may need to adjust yours by only -3%, or maybe +2%....
that's why you need to log/monitor the data for YOUR specific truck and make the necessary adjustment that's correct for YOUR vehicle...
here's info on how to do a cruising log to check your ltfts, how to adjust your fueling, and what parameters you need to log/monitor...
jrmybck
RE: 03 silverado
Post by jrmybck »
when i let off the throttle my reading goes to 0. when i get on the gas it goes up. these guys are claiming the oppisite. whats wrong here. thanks for the help. are these guys in the negative. thats why they go up when off the gas. maybe
RE: 03 silverado
they will go up/down when you let off, get on the gas... that's normal and doesn't matter...
look at what they're reading when you're driving/cruising steady on the highway, like the info at that link tells ya...
AKAssasain
RE: 03 silverado
Post by AKAssasain »
One the subject of LTFT's Do I want WOT slope within the -2-0 range as well? Im at about +4 now, I kicked em down about -5 as per the thread recomendataion.
After getting the LTFT's dialed i def noticed a difference, runs good. IMO
RE: 03 silverado
no... you need to get the normal driving/cruising average ltft's in the 0 to -2 range (get to be at -1.xx or -2.xx)... then at WOT, they should be 0 or slightly negative...
the ltft's are not used for WOT - only for part-throttle normal driving, so don't try to adjust them for WOT, because you will screw up your part-throttle fueling...
AKAssasain
RE: 03 silverado
Ok yeah i got that. ltft are steady -1.56,
Under WOT Fueling you have 3 RPM ranges to adjust correct? SO around 0 or just under would be good. Yeah I used the wrong term (slope), meant fuelling. Sorry
jrmybck
RE: 03 silverado
Post by jrmybck »
my injector slpoe is at -11. that put my ltft between -2 and 0 at a stedy cruise 55mph. seems fine. i am not getting any knock with a +10% adjustment. i only ever see knock at lower rpms. it was that way stock. i have not added timing to 2000 - 4000 rpm range.
