cot
RE: cot
COT stands for catalytic overtemp protection. Basically, this part of the software uses a formula using the sensor data from intake temperature, coolant temp, engine speed, load, etc, to estimate how hot the exhaust is and therefore how hot the exhaust components are getting.
When catalytic converters get too hot for an extended period of time, they will prematurely break down and fail. To keep them working properly, the PCM will add fuel to "richen up" the fuel mixture to cool down the exhaust gases when the temperature is estimated to exceed 1650 degrees. This will significantly reduce power output when it kicks in.
So, if you have the catalytic converters removed, then you should disable this so that you dont have this strategy kicking in. But, if you have your catalytic converters still on the vehicle, then you should leave it alone so that you dont damage your cats.
RE: cot
if you have cat's do not touch or change the COT setting at all.... leave it where it is...
Re: RE: cot
I can do that. Thanks!06MonteSS wrote:if you have cat's do not touch or change the COT setting at all.... leave it where it is...
2002 Corvette Z06 u7198 9r15, no other mods
RE: Re: RE: cot
Can I turn off the CAT and then turn off the COT ? If so how could it be done.
Re: RE: Re: RE: cot
This requires a custom tune.GeeTeePT wrote:Can I turn off the CAT and then turn off the COT ? If so how could it be done.
RE: Re: RE: Re: RE: cot
You can not turn off the cats. You have to remove them.....................and then turn off the COT. There are no other options.
