TIRE SIZE
RE: TIRE SIZE
What vehicle?
RE: TIRE SIZE
After you select the tune, choose modify tune, modify parameters then goto axle ratio.
RE: TIRE SIZE
I made it to that point and all I see gear ratio and Tire Revs.mikel wrote:After you select the tune, choose modify tune, modify parameters then goto axle ratio.
Is there a formula I need to use?
RE: TIRE SIZE
I still can't find tire size on the Trinity, even though it states it in the manual.
What's up?
What's up?
- Vas@Diablosport
RE: TIRE SIZE
For tire revs per mile, measure your tires from the ground up, and divide that number in inches into 20168.
for example; 28 inch tires = 20168 divided by 28 = 720 revs per mile
i hope this helps
i hope this helps
No, i don't work here.
RE: TIRE SIZE
I'll try that, but why does it state I can change the tire size yet I can't find this
