What is the BEST older Crom for The 6.0?
Jpritchard
Just trying to figure out what the best older crom file for power and fuel mileage is?
RE: What is the BEST older Crom for The 6.0?
I put the 8R10 crom in my 07 F350 and the power is great.I didn't get to run it enough to check the fuel mileage yet though,but I will keep you all posted.
Ran truck today around town,short trips not over 10 miles and it is averaging 14.5-15 mpg on the 8R10.
Went on a trip to Columbus Ohio yesterday.Had the cruise set to 70MPH.Ran over 350 miles and still at half tank.My reader is posting 20.3 right now and is usually right on when I test is vs. hand calculation.It was windy on my way out and raining and wind coming home.This includes interstate and local roads.
Thanks for posting that info bigroc. I would be happy to get 20 MPG again. I will try that cal after i get my truck flashed back and get rid of of this crappy new cal. Did this reduce your turbo lag any? I have noticed mine got worse after Ford flashed it last. Maybe its just me, but it seems worse.
2005 Ford F-250
Lariat Crew Cab
6.0 Powerstroke
Cat/muffler/EGR deleted
U7165 Predator
ver: 8r14 currently
Lariat Crew Cab
6.0 Powerstroke
U7165 Predator
ver: 8r14 currently
Santiago22
BIGROC,
What verision did you start with or was the 8r10 in the Predator when you brought it? I have verision 7r80 and I'm nervous to update to any of the newer programs. Reading other postings it sounds like I may run into problems going to another verision. Do you have any mods or running stock?
jtc1983,
May I ask what verision are you running and what mods other then the Cat/muffler delete?
jtc1983,
2004 Ford F350
6.0 Powerstroke
U7165 Predator
Ver: 7r80
6.0 Powerstroke
U7165 Predator
Ver: 7r80
Wow, 7r80?
I assume you have never had that truck to the dealership...dont start now!!
Santiago22
No sir,
Never will, should I just stay with what I have?
2004 Ford F350
6.0 Powerstroke
U7165 Predator
Ver: 7r80
6.0 Powerstroke
U7165 Predator
Ver: 7r80
Yes...
Santiago22
mikel,
Thanks, Should I be worried about blowing a head gasket if I use the Predator programer? Do you know what kind of pressure is generated with the 7r80 tune? Is the tune just a timing and trany shift point change? I know that the 6.0 is very senstive to heat and pressure.
2004 Ford F350
6.0 Powerstroke
U7165 Predator
Ver: 7r80
6.0 Powerstroke
U7165 Predator
Ver: 7r80
9secondchev
Could someone send me a copy of 7r80 or 8r10 or something good i finally got rid of all of fords crap!!
Santiago22,
I am currently running 9r11. That will change as soon as I get rid of Fords newest cal. No other mods at this time. EGR delete will be next since warranty just ran out. As far as updates - stick with what you have and avoid all Ford dealers if you can.
9secondchev,
I am still waiting on PHP to fix me up. How long did it end up being for you? It has been a month for me and still waiting. Tell me its worth it
9secondchev,
2005 Ford F-250
Lariat Crew Cab
6.0 Powerstroke
U7165 Predator
ver: 8r14 currently
Lariat Crew Cab
6.0 Powerstroke
U7165 Predator
ver: 8r14 currently
Santiago22
jtc1983,
About how long have you been running your 9r11 tunes or a better question how long have you been running Predator tunes on your truck.
2004 Ford F350
6.0 Powerstroke
U7165 Predator
Ver: 7r80
6.0 Powerstroke
U7165 Predator
Ver: 7r80
Re: RE: What is the BEST older Crom for The 6.0?
About 6 months. During this time I had the oil cooler replaced under warranty, but that is a fairly common problem with these so I dont know if the tuning expidited that or not. I doubt it. I do not recommend 9r11. The only reason I am running it is due to the fact that this is the only crom that Diablo has that will work with VXCF9 (Fords new strategy). I will be getting rid of that hopefully next week. At that time I plan to roll back to the 8r10 crom that bigroc was discussing earlier. Unless someone knows a better one.Santiago22 wrote:jtc1983,
2005 Ford F-250
Lariat Crew Cab
6.0 Powerstroke
U7165 Predator
ver: 8r14 currently
Lariat Crew Cab
6.0 Powerstroke
U7165 Predator
ver: 8r14 currently
9secondchev
RE: Re: RE: What is the BEST older Crom for The 6.0?
jtc1983 the new programing works great I am back to the way things used to be, as far as rolling back to the 8r10 mine wouldn't let me, I am running the 9r12a now and it seems to work pretty good though i haven't got to check the milage yet but i'm sure it can only get better than it was.
