WOT Fuel adjustment
BlackR/T6Speed
WOT Fuel adjustment
Just had two quick questions. I've got a 2009 Chally R/T six speed with CAI, thermo, catch can, catless mids, E3 spark plugs, and resonator delete pipes. What would be a good starting point to set my WOT fuel ratios at? And does anyone reccomend messing with the spark? I'll be taking it to the drag strip in a few hours.
RE: WOT Fuel adjustment
Add 10% fuel for the mids, and run the CAI tune.
Get rid of the E3s...
yeah, E3's are junk... lotta problems with those plugs...
have seen/read a lot of people have issues with them, like a lot of misfires and such....
fixed the problems and regained their performance by going back to stock plugs...
are we repeating ourselves here??
ok, I'll play along...
search around forums...
I did not know they made E-3s for the 5.7. I looked them up and got a message saying they did not make a plug for my car. That said these guys are correct. Get rid of them. The reason people have trouble with them is they retain to much heat at the electrode which will cause the mixture to fire prematurely (before the spark plug fires) The original plugs are copper clad for better heat dispersion...
Charger250
Charger250
bighemitex
platinum plugs on a hemi is a no-no. guys that were using platinum plugs in hemis were having issues with the platinum coating on the electrode melting off then you might have the issue of the platinum chunk bouncing around the cylinder and a spark plug that isn't working properly. Copper plugs are the best way to go on these engines. I wouldn't put those stock champion plugs in any thing i own so I switched to NGK v power plugsCharger250 wrote:Platnum plugs are rated at 100k miles. Thats an advantage. Some cars have them stock so the manufacture can say the car has a 100k miles per tune up.
2003 RCSB Hemi Ram - Stock 20s, U7137, AIRAID CAI, 180* Jet T-Stat, Black Magic E-Fan, 3 Inch Cutout, Hooker Aero Chamber Muffler, TMR Mod, NGK 5306 plugs, Taylor 8.2 thundervolt wires, Pacesetter Longtube Headers, Pacesetter ORY, magnaflow cat, Innovate LC-1,
