2006 3500 5.9 engine surging
Sb3500
Post by Sb3500 »
I bought a predator about 1 month ago truck was fine before i put it on. I put on on the performance economy tune and all of a sudden my truck hunts or surges when decelerating (sometimes real bad) and when at idle. Makes my truck sound like a bag of poop not to mention is dangerous.
Anyways return to stock bring to the dealership, new lift pump, and turbo , truck is running amazing (stock) Updated the predator to the latest version, retuned my truck to performance tune same issue. Ideas anyone
Truck 2006 Ram 3500 dually crew cab 4x4 5.9, 91,000kms.
duallydave
RE: 2006 3500 5.9 engine surging
Post by duallydave »
Try a different tune and see if it does it. Does it throw any codes when it surges
04 l/box.predator quad race x2 cammander.bhaf.6spd stick.
Sb3500
Post by Sb3500 »
Put the Extreme tune on it today and it still did the same thing, returned to stock , tried the economy tune still does it.
Sb3500
Post by Sb3500 »
Part number of tuner is 159402, checked with the tuner if there was any codes and there wasnt.
try this:
options/troubleshooting/restor original backup, then reload the tunes, see if that helps.
ropnjessi
Post by ropnjessi »
So is the Predator updated to the latest CROM file?
03'/305 Dually 4 x 4
Platinum FASS/150,/Level II CP3, 60hp.Inj.
Stage 1 cold air box, BD Intercooler
Smarty SSR,62/65/13ss, CFM+
Goerend Trans. Westach, Fuel/Rail Gauges
2011 Laramie Longhorn All Stock
Sb3500
Post by Sb3500 »
updated to 9R06
Sb3500
Post by Sb3500 »
The truck feels and sounds like it has a big ole cam in it. Shakes real bad too. Also how do i use the idle up feature? Sorry for so many questions, appreciate all the help.
exolent
Post by exolent »
I am having the same issue with my 2006 2500 5.9. Programmer is updated to 9R06 and still shakes and surges. I have done the Restore Original backup before and it has not helped. Surging and shaking happens in all levels, not so bad in Tow mode. Real bad in performance (which is what i want to run on)
2006 Dodge Ram 2500 QC Laramie Auto
Smarty
Willy's Whistler
4" Straight Pipe
Arson III
FASS150
07megacab
Post by 07megacab »
Sounds like an injector to me. Rev it up in neutral, does it take a few seconds to come back to idle, or "stairstep" back down? You may have an injector bleeding fuel when its not supposed to. Happens ALOT
exolent
Re: RE: 2006 3500 5.9 engine surging
Post by exolent »
07megacab wrote:Sounds like an injector to me. Rev it up in neutral, does it take a few seconds to come back to idle, or "stairstep" back down? You may have an injector bleeding fuel when its not supposed to. Happens ALOT
Yeah i know, you post this everytime this issue is said. Purchased Smarty problem is resolved.
Smarty
Willy's Whistler
4" Straight Pipe
Arson III
FASS150
07megacab
RE: Re: RE: 2006 3500 5.9 engine surging
Post by 07megacab »
Sorry, trying to help. Somone asked a question and it had been a couple of weeks since a response. It seems to make sense to me that every time I read the same issue, I recommend the same solution...
