2000 7.3 need help.
sk8ter555999
2000 7.3 need help.
Post by sk8ter555999 »
I have a 2000 f350 7.3. Trying to figure out wat would be the best thing to do for the tire sizes... I have an 8 inch lift with 38s. And wat should I set the base nov?????
RE: 2000 7.3 need help.
That will not adjust the speedo.
ash
Post by ash »
but even so. does it change the shifting. cause with the bigger tires. you are changing your drive ratio. what would be best to change for this higher gear ratio.?? i have 40's on my 2002 f350 and wanted to fix the shifting speeds. thanks
