Hi,
I get the attached error every time I access CMR software, I re-installed the software with no luck, the same error keeps appearing.
thanks
Error every time I access CMR software
- error.jpg (124.02 KiB) Viewed 9880 times
RE: Error every time I access CMR software
I get it on v4.8.0.0 also. Try the following:
Open Windows Explorer to C:\Chipmaster Revolution.
Launch Chipmaster_Revolution_4.4.7.1.exe (double mouse click).
It will post a dialouge of Not Registered, etc, etc. Just login with your CMR credentials (login/password).
Restart CMR version 4.7.0.9.2. It should now run.
Jim be the man, behind the glass......
Johan< @ >DiabloSport.com
Diablosport INC
Research & Development
Diablosport INC
- paul@thrill-ride
I get the same error and did what JIM said and it still doesn't work any ideas?
Assuming you have 4.7.0.9.2 and recent version of DSDL installed. Try installing the 4.8.0.8 update found in http://www.diablosport.com/index.php?mo ... 2&cmr=soft
Be sure to install in same C:\Chipmaster Revolution folder as 4.7.0.92. Running 4.8.0.8 may have a pop-up indicating Burner file missing, just select OK.
- paul@thrill-ride
Re: RE: Error every time I access CMR software
That seemed to work! THANKSjimb wrote:Assuming you have 4.7.0.9.2 and recent version of DSDL installed. Try installing the 4.8.0.8 update found in http://www.diablosport.com/index.php?mo ... 2&cmr=soft
This happened after it downloaded some updates then all of a sudden ChipmasterRev got that error. How do I know if the DSDL version is recent?
RE: Re: RE: Error every time I access CMR software
DSDL will indicate if a new rev is available. The current rev is 2.2.2.4.
