Throttle lag
Throttle lag
Can a Predator be used to remove the lag in throttle response?. Someway that multiplies the accelerator pedal
sensor signal, making the accelerator pedal more sensitive.
I have read about the Sprint Booster, and everyone claims that this is an amazing device. Since I already own a Predator, I was wondering if it can do the same thing.
Thanks in advance for any input.
http://www.crosslake.net/~dbipes/sprint ... ooster.pdf
RE: Throttle lag
there is already an increase in response in the canned tunes, if you want more, export and post your last tune written.
silverdaytona
RE: Throttle lag
Mike, heres my last wriiten tune. I need less TQ management on my 05 ram hemi,and ill take the throttle sensitivity increase. Part# U-7137,r09,2005 Dodge Ram 1500, 2wd, Hemi
- PCM_56028958AI_Perf_87oct_modified.drg
- (4.25 KiB) Downloaded 203 times
- TCM_05094258AD_Perf_Trans_Tune.drg
- (1.25 KiB) Downloaded 165 times
RE: Throttle lag
email sent.
silverdaytona
RE: Throttle lag
Thanks! I recieved the E-mail. I will try it out and let you know how it works.
Re: RE: Throttle lag
Thanks Mike, here's my last tune written, please increase my throttle response.mikel wrote:there is already an increase in response in the canned tunes, if you want more, export and post your last tune written.
Thank you for you help.
- PCM_68054128AD_Perf_93oct.drg
- U7136 Perf.93oct.drg
- (4.25 KiB) Downloaded 253 times
silverdaytona
RE: Re: RE: Throttle lag
I tried to load the modified files that you sent me but the Predator would not load the files into the truck. The file you sent for the PCM was (Perf 87) but not (Perf. 87 modified) like the file that I posted for you. Please check that out for me. Thanks.
The PCM tune I sent you should have _001 in the name.
Here you go:ggaliano wrote:Thanks Mike, here's my last tune written, please increase my throttle response.mikel wrote:there is already an increase in response in the canned tunes, if you want more, export and post your last tune written.
- pcm_68054128ad_ETC.drg
- (66.01 KiB) Downloaded 187 times
silverdaytona
It does have 001 in it but it has perf.87 and not perf.87 modified like the file I posted.
silverdaytona
The Predator states that the file AD is not right and therefore will not be used.
silverdaytona
Tried to load the files you sent me yesterday, again this morning and the message it gave me was Problem with Custom Tune 05094258ad wont be used. ad is the trans part of the tune.
Thanks Mike, the custom tune you sent me worked perfectly. I'm trying different WOT fuel/spark adjustments to see which suit me best
thanks again.
thanks again.
Winter is coming!
silverdaytona
Thanks Mike! The pcm tune you sent sure did the trick. Throttle sensitivity is right where I wanted it. It feels like it is a cable actuated throttle. Tap the gas very lightly and it jumps.
Awesome.
