2010 Challenger SRT8 6 Speed and u7135 Tuner Problems!!
willtransco
Went out to hook up the Tuner to Car..I had been running it on a 2008 Charger R/T and all was fine.. NOTE..I did the latest update crom and then get to Car..boot up and I get the following Message
Predator u7135 does not support Calid:68004309AD. Tool update might be required.
Car is a 2010 Challenger SRT8 6 Speed
u7135-9r12 was installed..I installed u7135-9r27.crom
and still got same message..so I reinstalled 9r12
Tuner has always worked well till now..
Need some Info here..
RE: 2010 Challenger SRT8 6 Speed and u7135 Tuner Problems!!
That CalID isn't supported yet. Gonna have to wait until they get the code and add it in.
willtransco
Any idea when... Tuner is a papeweight at tha moment
willtransco
What I need is a Trade in..and get a Trinity!!! Whoo Hoo!!
They have the same tunes and the same support. If the Predator doesn't work with your Cal, neither will the Trinity.
Keep an eye out for 9r28.
Gooichimotors
When is 9r28 due to be out? Ive got a 2010 srt8 challenger with the same exact problem. I did a ton of work to my car this past weekend and had to wait to get my tuner in the mail. Now i have it and I can't even use it! Not to mention when this 9r28 thing comes out ive got to figure out how the heck to update my predator... Seems like a lot of crap to do for something that should be plug n play! Please help!!
Can't be plug n play when Chrysler uses a bunch of different Cals every year, and each one needs to be added in as they're released and decoded.
Gooichimotors
That's crazy! Is that why some of the 2010 srt8 challengers out there can run predators, and mine and willtransco's can't? They have different cals for the same yr/model??!!
I just want to unleash the fury, hopefully they can get 9r28 out soon!
Yep, thats why. You can have the exact same year, make and model and there could be 6 or 7 different CalIDs.
willtransco
Where is 92r28???
willtransco
Guess I am outta luck..Installed the v.9r27 crom..Tool reports :
Incompatable Hardware.(No serial flash found)
Contact Tech Support
(561-908-0040 x1
www.DiabloSport.com
(561-908-0040 x1
www.DiabloSport.com
willtransco
Re: RE: 2010 Challenger SRT8 6 Speed and u7135 Tuner Proble
OK when that comes out..how am I going to get the crom on the tool???Mike_Levy wrote:That CalID isn't supported yet. Gonna have to wait until they get the code and add it in.
When I load 9r27 now I get errors!
RE: Re: RE: 2010 Challenger SRT8 6 Speed and u7135 Tuner Pr
On top off this page click on support and then tech support..At the bottom you will find all the pdf information you will need too update your crom and etc,,,
2009 Charger SRT,91 tune 180 thermo
You need 9r27l.
