2004 neon srt4 tune and won't start
gearhead89
I have a t-1000 and I was tuning my 04 dodge neon srt4 and half way into loading a custom tune it stopped. Every time I plug the trinity in it says the last tune didn't finish would you like to reload the original tune but when I try to it says it is unable to load and my car won't start at all. Any ideas or can one of the moderators help out with this?
gearhead89
RE: 2004 neon srt4 tune and won
Sorry I just notices I put this in the predator section and I have a trinity.
got any aftermarket electronics?
turbo timer, remote start, etc?
disconnect them, and try again.
Remove them from the factory harness.
gearhead89
Yes I do have some and I've removed them. Still haven't made any progress. Is there anything else?
gearhead89
yeah...good question.
Was voltage removed from the PCM?
Did the batter die?
Did the tool get unplugged?
If none of the above, and it seemingly failed 'on its own', then some sort of electronics that did not come from Dodge are causing the issue...
Did the batter die?
gearhead89
man, Im dying to help you, but details are essential.
you 'think' yoo lost power, or you 'think' you lost connection?
What exactly happened????????????????
gearhead89
gearhead89
gearhead89
fix that, charge the car, and try again...losing batt voltage during a flash is one of the worst things that can happen, as it can lead to a damaged PCM in some cases.
