Part Number: u7131
Version: v.1r09
2006 Dodge ram 2500, 5.9L Cummins Diesel
So I installed 1R09 today, when I hooked the tool back up to the truck and tried to load the tune I got an error "this tool is not licensed for use in this vehicle"
When I look through the tool menus, there is no VIN saved anywhere. Any ideas how I can get the tool working again?
2006 Ram 2500 - Update to 1R09 problem
RE: 2006 Ram 2500 - Update to 1R09 problem
Did you restore the original tune before updating?
did you select the correct vehicle after the update?
Yes, I restored the original tune before the update.
I don't remember if I selected the correct vehicle after the update. If the option was presented to me, it's not that hard, but I guess I could have messed it up. Is there a good way to check?
just redo it, options/change vehicle type.
Well that seems easy enough, I'll try it when I get home.
So, I changed the vehicle type and tried again, same error. Any other suggestions?
The trinity is still out of commision, any other suggestions??
