Adjusting Parameters
Mike'sLS3
Post by Mike'sLS3 »
If you adjust a parameter, i.e spark timing, on a custom tune and install that tune with the adjusted parameter, then restore back to the oem tune, then reinstall the custom tune: When you reinstall the custom tune is it the original custom tune or is it the custom tune with the adjusted parameter?
Re: Adjusting Parameters
when you restore the backup it resets the params, so the change wont be there the second time unless you manually make it.
Mike'sLS3
Post by Mike'sLS3 »
Thanks for the response.
Rustysocket
Post by Rustysocket »
I'm kind of slow.... sorry.
Just so I am clear. If I restore my car to stock tune, that will also reset the diablosport tunes to the default values on the device as it was shipped? Removing any of the adjustments I have made.
So as long as I don't return to stock. I can continue to make adjustments to individual parameters on a case by case basis and it will retain all of them?
I'm sure someone wants to do this to me.. :normal: :punisher:
