tire size callibration
brentwood
Post by brentwood »
I still can't change my tire size on my trinity. I've tried by diameter and by metric size numerous times. Is there a fix for this?
Re: tire size callibration
vehicle?
revision?
error?
Help me, help you :)
brentwood
Post by brentwood »
2012 Dodge Ram
I'll get back to you with the exact error msg
if it says it failed after you set the tire size and cycle the key, it lied :)
it is working.....
mopar11
Post by mopar11 »
mikel wrote:if it says it failed after you set the tire size and cycle the key, it lied :)
it is working.....
Thanks for the laugh. :lol:
brentwood
Post by brentwood »
i'm running v.1r09f
ok, so it says failed after trying to callibrate like you said.
brentwood
Post by brentwood »
do i have to reinstall the tune or is it modified on my currently installed tune?
no, the tune is unaffected.
I am serious, when it says it failed, it lied, as long as it had you enter the values and cycle the key.
You can confirm with GPS :)
brentwood
Post by brentwood »
ok, thanks for your help.
djwintz
Post by djwintz »
I bought a 2012 Ram 1500. It had 17in tires, I put on 20's and put the #'s in the Trinity. Now the speedo is 10 kms different then my GPS. How do I get the proper speedo reading?
make some adjustments to the settings until it is correct :)
djwintz
Post by djwintz »
Got it figured out, thanks Mikel. Was not hitting the enter button after each entry. Works good if ya do it properly, lol.
