Intune gets stuck on restoring tire size
trying to restore my original tune after the intune failed to write diablo tune
i updated the tuner, but the intune still freezes on restoring tire size on original tune restore
heres all the tunes i have on it
the truck will still start and move just none of my gauges work.
vehicle is a 2005 dodge ram 1500 slt 4.7l
- info.xml
- (508 Bytes) Downloaded 253 times
- TCM_56028953AEA_LastTuneWritten.drg
- (115.49 KiB) Downloaded 335 times
- TCM_56028953AEA_Backup.drg
- (115.49 KiB) Downloaded 233 times
- PCM_56028942AF_LastTuneWritten.drg
- (57.69 KiB) Downloaded 211 times
- PCM_56028942AF_Backup.drg
- (57.68 KiB) Downloaded 268 times
Re: Intune gets stuck on restoring tire size
after looking around i see someone else had this happen in the thread "inTune Troubles"
could really use help here thanks
try disconnecting the battery for a minute.
tried still nothing
try restoring QA from the QA menu, then restore the backup.
QA ? I'm not quite sure what that is
quick adjust.
ok well im not finding a QA menu on my intune is there any file that can be downloaded that will fix it from getting "hung" up and restoring tire size right after writing the back up tune
Idk if force original tune would work except it gives me a key code and asks for a password
quick adjust is after tune vehicle/write vehicle.
All I have after that is write vehicle restore vehicle and adjustable parameters. And after going to any of those it just says no ecu found
OK now the truck won't even start
what happened?Andrew.S wrote:OK now the truck won't even start
please give us a call with the tool powered up in the truck.
im not sure what happened would start yesterday and i havent done anything new but try getting to QA menu
its powered up and calling now
