Inutune with 1r01h firmware loaded.
Won't load the 'group_update.itfg' file because it is not registered.
I dragged the registration.itf file to the F: drive, it restarts and goes through the same process of never giving me a registration form and coming up with the same error msg. I have tried many, many times.
What to be done?
Update/registration issue
Seth Patterson
FederalPerformance.ca
Re: Update/registration issue
post or send me the info file please.
1 info file attached
- info.xml
- (436 Bytes) Downloaded 209 times
Seth Patterson
Hello- Bump.
This thing is still sitting on my desk.
Seth Patterson
sorry...must have missed this. You can always email meFPSeth wrote:Hello- Bump.
Put this on the intune drive and the tool will be registered.
- registration.itf
- (973 Bytes) Downloaded 202 times
playboy35792005
I don't think I'm registered I'm new to this just bought it and lost the registation
<?xml version="1.0"?>
-<tool_info><main svn="6786" sw_rev="1r03p" full_version="InTune-1r03p 11/04/2013 10:06:54 AM"/><registration status="1" sn="J24IM46-4"/><cal_id CM1="05094258ADA" PCM="56028958AI"/><restore bc="13" vin="1D7HA16D55J517060" id="0"/><system_db vin="1r01c" dtc="1r01a" info="1r01b"/><db pid="1r01a" tune="1r01b" mfr="DCX"/><db pid="1r01b" tune="1r01o" mfr="FORD"/><db pid="1r01a" tune="1r01t" mfr="GM"/>-<license tuned="1" avail="1"><tuned vin="1D7HA16D55J517060"/></license><updates count="4"/><oem tool_oem="DIABLO"/><reg reg="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"/></tool_info>
playboy35792005
when I restore settings to factory original then restore tire size frezzes up and does nothing
the tool is definitely registered. Try this. Go to quick adjust and hit yes to restore quick adjust, then go to restore vehicle and you should be all set.
