Ford ranger tune
Ford ranger tune
I have a 08 Ford ranger FX4 4.0
speedo isn't right (35s on the truck)
no option to change speed limit
rev limiter isn't working properly in neutral rev limit is still 3000 rpm
here is a copy of the tune I'm using right now great tuner its fast!! and the MPG when I keep my foot out of it is awesome for being on 35s
could you please take a look at this for me thank you.
Re: Ford ranger tune
for tire size changes to take effect, you have to flip the enable axle ratio change param, done here.
speed limit is raised to 145 in the tune
be sure to reset parameters when loading this tune.
- pcm_pyfk3a7_lasttunewritten_fix.frg
- (347.47 KiB) Downloaded 302 times
Thank you and what gear ratio did you set it to? and how much Spark advance is safe to use?mikel wrote:for tire size changes to take effect, you have to flip the enable axle ratio change param, done here.
it showed stock gears of 4.10:1.
spark is determined by octane, the tunes are already set up properly for spark based on the octane you chose.
In case something goes wrong and I need to reload a tune or set back to stock or whatever how do I get the speedo changed to being right? trying to figure out so that I have to bother you again sorrymikel wrote:it showed stock gears of 4.10:1.
when I put this tune on my tuner a message pops up saying it is already on there and then deletes the file please help!mikel wrote:for tire size changes to take effect, you have to flip the enable axle ratio change param, done here.
I have not hooked tuner back into truck since yesterday and what to get this figured out before I hook it back up
sure you did the one labeled _fix?
yes I tried it 3 times. I saved the original tune then took it off the tuner and put the _fix in its place and the tuner deleted it again.mikel wrote:sure you did the one labeled _fix?
how can I change the tune that is on the tuner (the original one) when its hooked up to the truck to have the speedo right and the 145 MPH speed limit?
go tot he truck and see if it lets you load the custom tune....
the original tune with the wrong speedo will work but there no option for the working speedo tunemikel wrote:go tot he truck and see if it lets you load the custom tune....
- j.mike@diablosport
I know it seems confusing at first, but the files are not actually deleting from the tool when you drop it into the INTUNE drive, they are actually importing to he tool from the drive. If you transferred a file to the INTUNE drive and it didn't disappear, that would mean it wasn't formatted properly. The 'tunes' folder only ever contains the last tune written and Original Backup (stock tune) when the tool is married.Bwymike wrote:yes I tried it 3 times. I saved the original tune then took it off the tuner and put the _fix in its place and the tuner deleted it again.mikel wrote:sure you did the one labeled _fix?
When you get the tool plugged into the vehicle, select Tune Vehicle / Write Vehicle / Custom Tunes and the tune Mike L made for you should be there.
Diablosport Sales Team
Caffeine Engineer
Please do no PM me! Send an email to [email protected] if you need to contact me.
Caffeine Engineer
the speedo works on this tune but the truck is SLOW with it I don't know if the mistake is on my end or yours but it can hadly spin the tires in the rain and the other tune can break them lose when its dry
on my intune there is no option change: speed limit, rev limit in neutral, torque management (no 100% sure if the truck has this), no way to tune off TPMS, and the speedo cal doesn't work. could you see if in the next update you could work these things in? thank you
can I have a fresh copy of the last tune written from the tunes folder now with my tune loaded?
here it is speedo is actually a little fast on it. the right rpm for my truck (35x12.50x15) I think is 596
try this one
- pcm_pyfk3a7_lasttunewritten_new.frg
- (347.47 KiB) Downloaded 311 times
