Just received my i-1000 and went through the hour long update process. Then tried to tune/write vehicle and process fails with error message:
Failed to read ECM Original Backup, Error Code = 16
Car is 2013 Chevy Suburban 5.3l engine. Programmer serial number is X000IVUL3D
Need some help. Thanks.
Initial Install Probs
Re: Initial Install Probs
save the attached file to the intune drive on the pc and let it reboot, then go to the vehicle and try againjeffbtx wrote:Just received my i-1000 and went through the hour long update process. Then tried to tune/write vehicle and process fails with error message:
- InTune-1t03uj.itf
- (1.81 MiB) Downloaded 108 times
OK thanks - I'll report back later.mikel wrote:save the attached file to the intune drive on the pc and let it reboot, then go to the vehicle and try againjeffbtx wrote:Just received my i-1000 and went through the hour long update process. Then tried to tune/write vehicle and process fails with error message:
That seemed to do the trick. Got through the process and now off to test drive - just 87 octane tune + turned off DoD. What was the file you sent?jeffbtx wrote:OK thanks - I'll report back later.mikel wrote:save the attached file to the intune drive on the pc and let it reboot, then go to the vehicle and try againjeffbtx wrote:Just received my i-1000 and went through the hour long update process. Then tried to tune/write vehicle and process fails with error message:
Thanks.
a fix for that bug
