Hi,
I installed the latest version of the Dataviewer on my laptop running Windows Vista. However, it failed to open and says:
"Dataviewer.exe - Unable To Locate Component
This application fail to start because mfc71.dll was not found.
Re-installing the application may fix this problem."
I tried to uninstall and install the program, but still no success. Btw, the DSdownloader works properly.
Any idea?
u7135 Dataviewer error: mfc71.dll not found
- Error Dataviewer.jpg (45.4 KiB) Viewed 1813 times
RE: u7135 Dataviewer error: mfc71.dll not found
I googled and downloaded the dll file. Now it works
On Vista machines the installer does not install that DLL because Vista is *supposed* to already have it. Interesting, if this keeps popping up then I will have to re-enable that for Vista. Well done working around it.
johnc <at> diablosport.com
This issue has been fixed in the latest version.
