2014 Mustang 5.0
armyguy202000
2014 Mustang 5.0
Post by armyguy202000 »
So I have a 2014 5.0 3.73 gears, JLT CAI, Flowmaster super 44'axel back and that's it. Im running the JLT 91 octane tune. When I go to adjustable parameters the gears are set at 3.31 I believe. If I change to 3.73 will everything else stay the same. Also is there anything else I should adjust I only ask because I don't notice much if any difference in performance. Thanks
sohfast94
Re: 2014 Mustang 5.0
Post by sohfast94 »
Please post your last tune written out of the tunes folder.
Insert Clever comment here...
armyguy202000
ok
PCM_FPFD32A_LastTuneWritten.frg
(592.97 KiB) Downloaded 211 times
armyguy202000
any thoughts? I saw a few forums you helped some guys out in before. Hope to get the same results. I can really tell the difference since I changed to 3.73 gears on the tune I posted. Gas milage sucks though on the highway im only getting 16-17. However, I didnt buy a 5.0 for the gas milage just think its bad based on the post of others.
sohfast94
Post by sohfast94 »
Here you go sir. Sorry for the delay.
pcm_fpfd32a_r2.frg
(549.99 KiB) Downloaded 215 times
armyguy202000
I am running the last tune that you sent me and when I come to a stop when my engine is cold my car will die. Also if I let it sit and idle for to long the idle will start to go up and down by 2-3 hundred rpm. I have also added an x-pipe by Pypes but it was doing it before the addition.
sohfast94
Post by sohfast94 »
Try that
pcm_fpfd32a_r2b.frg
(550.08 KiB) Downloaded 278 times
armyguy202000
Attached is the data log after running the tune you just sent. Please review.
1ZVBP8CF6E5281117_01.log
(1.7 MiB) Downloaded 207 times
armyguy202000
I am adding shorty Flowmaster scavenger series headers today can you adjust the last tune if needed?
shorty headers will not require any changes ideally.
armyguy202000
Something is going on. Since I added them when cold started I get the loud pop noise from my JLT CAI like before adding the tune for the CAI. Then after warm and sitting at idle for more than a min or so idle starts to fluctuate to the point of almost dieing.
burn up an O2 harness?
armyguy202000
No
sohfast94
Post by sohfast94 »
Post what's in the tunes folder on the tool currently.
armyguy202000
This is the current tune im running
pcm_fpfd32a_r2b.frg
(550.08 KiB) Downloaded 229 times
