n2mb wot box not working with diablo intune for caliber?
miztercorny02
Post by miztercorny02 »
hello,
i have an 2008 caliber srt4, i just recently purchased a n2mb wot box, and with some research, found that apparently, it does not work with the diablo tune unless given a custom tune. i contacted customer service and he said to ask here. he also said if needed, the custom tune is free. could you help me please?
thank you
sohfast94
Re: n2mb wot box not working with diablo intune for caliber?
Post by sohfast94 »
Just post the tunes from the tune folder here. I'll make the necessary adjustments
Insert Clever comment here...
miztercorny02
sorry, where would i find the folder?
on the drive called intune.
miztercorny02
here you go sirs. I believe that should be it. any more info, please just let me know. thank you.
PCM_05187661AF_LastTuneWritten.drg
(636.02 KiB) Downloaded 618 times
sohfast94
Post by sohfast94 »
Need the backup as well please.
miztercorny02
here you go.
so question, what does the custom tune fix? will it actually let my n2mb work? sorry, i just people talking about this online.
(636.02 KiB) Downloaded 727 times
PCM_05187661AF_Backup.drg
(636.24 KiB) Downloaded 517 times
sohfast94
Post by sohfast94 »
Here you go.
pcm_05187661af_2step.drg
(577.36 KiB) Downloaded 460 times
miztercorny02
thank you, hopefully it works.
this is equivalent to the diablo tune right? using 93 octane?
JECU_CSRT4
Post by JECU_CSRT4 »
HI I TOO HAVE THE SAME PROBLEM WITH THE WOT BOX COMES IN LIMP MODE, THAT TUNE SOHFAST94 ALSO CAN I USE IN MY CALIBER SRT4 OR IS ONLY FOR MIZTERCORNY02?
THANKS
sohfast94
Post by sohfast94 »
Only for him. You want it you'll have to post your tunes as well.
JECU_CSRT4
HERE IS THE ORIGINAL BACKUP OF MI CSRT4, WITH THIS UPGRADE FOR WOT BOX CAN I USE TOO THE 91OCT TUNE AS WELL LIKE BEFORE?
PCM_05030396AJ original backup.drg
ORIGINAL BACKUP
(781.05 KiB) Downloaded 698 times
JECU_CSRT4
I FORGOT THESE :punisher:
PCM_05030396AJ_Perf_93oct.drg
(3.25 KiB) Downloaded 353 times
PCM_05030396AJ_Perf_91oct.drg
(3.25 KiB) Downloaded 458 times
sohfast94
Post by sohfast94 »
Which one are you running currently?
JECU_CSRT4
91oct
