ABS Light
ABS Light
I have a 2013 Jeep Grand Cherokee 5.7 Hemi. I adjusted the tire size to match my 275/65/18s and am now experiencing a stuck ABS light. I tried to reset to the stock tune but that did not fix the issue. I have the current 1r13 version applied to the trinity t1000. I was wondering if there were any other steps I could take to correct the issue or if there is a fix available online.
I also had a question about 87. Will I run into issues if I use 89 octane will running that 87 tune. I did not see any options for 89 on the device.
Thank you for your time.
Re: ABS Light
restoring the stock tune, then updating to 1r13d then reapplying the tire size should fix it.
98 will work fine with the 87 tune.
Re: ABS Light
Thank you for the quick response. However, I cannot find the version 1r13d anywhere on this site. Do you have a link for that download?. Thank you.
Re: ABS Light
restore the stock tune then connect to a pc, open dsdl, and it will auto update assuming the tool is registered.
BlackOverlandHemi
Re: ABS Light
Does this actually work?
Re: ABS Light
I plugged the device in and ran the downloader program. I didn't receive any new updates. I figured the site would host the last revisions of the .crom files but I was unable to find the update "1r13d". Is there a direct link to this download?
Re: ABS Light
its 1r13c actually, if the device is registered it will auto update, did you restore the stock tune first?
Re: ABS Light
I actually ran the update on the device prior to trying to change the tire size. I tried to reset to stock but the light still stayed on. I haven't flashed a full tune on the vehicle yet. I was planning on flashing the 87 tune. Will that fix the abs light issue, if I also set the tire size to what I'm running?
Re: ABS Light
Has a resolution been given for this ABS issue. I also input the tire size and got the light. Plenty of threads on the problem, but still yet see how to fix this?
Mongoose9400
Re: ABS Light
Help. ABS light stuck on. 2012 Jeep SRT8 after trying to adjust tire size. With the ABS light on is ABS disabled?
Re: ABS Light
is the device up to date currently?Mongoose9400 wrote:Help. ABS light stuck on. 2012 Jeep SRT8 after trying to adjust tire size. With the ABS light on is ABS disabled?
Mongoose9400
Re: ABS Light
mikel wrote:is the device up to date currently?Mongoose9400 wrote:Help. ABS light stuck on. 2012 Jeep SRT8 after trying to adjust tire size. With the ABS light on is ABS disabled?
Yes. Tool is up to date. Tool automatically updated yesterday. dcx 1r13c
Mongoose9400
Re: ABS Light
Just took the car to a dealer and got it fixed for $100. Just needed to reflash the correct (stock) size back.Mongoose9400 wrote:mikel wrote:is the device up to date currently?Mongoose9400 wrote:Help. ABS light stuck on. 2012 Jeep SRT8 after trying to adjust tire size. With the ABS light on is ABS disabled?
