A9L MAF voltage wont let me change
Mopac
Post by Mopac »
Hello, i have tried several of my versions of CMR and i cannot get the a9l tune to allow me to change the MAF voltage table.. when i change a number it goes all haywire and makes its something like a 9.4 or what have you... the maf im working with uses voltage all the way down to .3v when it idles.. any ideas? thanks Nick
Re: A9L MAF voltage wont let me change
did you try cmr 4471?
I just opened an a9l file and it allowed me to edit MAf curve no prob...what versions are you trying?
Mopac
Post by Mopac »
im using version version 4901 cmr.... i have also used 47092 .... where and how can i get the correct version to do this?
I just opened 4901 and edited it no problem, try deleting the matching ori from the ori folder and make sure view/set path settings has the right paths for ori and template.
Mopac
Post by Mopac »
i tried deleting the ori file for the tune and it didnt change it... i paths are set good.... i dont know what im doing wrong
try installing this version
CMR_5.1.1.14_update.exe
(9.5 MiB) Downloaded 332 times
Mopac
Post by Mopac »
i installed this version, and it does the exact same thing... i cannot manipulate the voltage part of the chart.... i can change the airflow part all day long.... i tried deleting the ORI file and made sure the pathways were to the correct folders....
delete the template and try again.
Mopac
Post by Mopac »
deleted template GUFBX and it says could not find template when i open the tune again, then it allows me to view the tune, however the same result... no voltage changes allowed..... it is downloading the template every time i delete it... when i enter it offline, it wont let me open the tune because there isnt a template...
post the file you are working with.
Mopac
Post by Mopac »
here is a test version.......
larrykerrtest.frg
(56.12 KiB) Downloaded 344 times
I can edit that fine as well.
can you describe exactly what you are doing?
Mopac
Post by Mopac »
I am trying to change the lower end of the voltage side of the chart (although any change to any of the voltage set points in the voltage column makes it go haywire) .... say i wanted to change the last voltage set point there from the .57 to .34 as a sake of reference... when i type the .34 in, and press enter to make the cell change, it changes the cell, but not to .34 as comanded, it changes it to like 12v, or 8v.... it goes completely weird... it doesnt do this with any other ecu strategy...
Mopac
Post by Mopac »
one thing i will say is that it does it on all versions of CMR that i have.... i use an older dell computer to run the burner version for chip tuning, and it does the same thing as my newer laptop that i use to tune newer vehicles...
