General Tuning & Factory Presets (Drive Modes)
I'm new to all of this.... I've got a 2015 Camaro ZL1
I have a few questions:
1 - Can Preset tunes be layered or is it just one at a time and your done?
2- Do Preset tunes effect factory drive modes? And do they over-ride Factory Modes?
(Five PTM performance levels or modes are available to accommodate the given ambient and track conditions, driver experience/vehicle familiarity and driver comfort levels. They include:
Mode 1 – Traction control set for wet conditions, with stability control on and Magnetic Ride Control set on Tour.
Mode 2 – Traction control set for dry conditions, with stability control on and Magnetic Ride Control set on Tour.
Mode 3 – Traction control set on Sport 1, with stability control on and Magnetic Ride Control set on Sport.
Mode 4 – Traction control set on Sport 2, with stability control off and Magnetic Ride Control set on Sport.
Mode 5 – Traction control set on Race, with stability control off and Magnetic Ride Control set on Track. Launch control tuned for VHT-prepped drag strips.)
What are the best presets to use?
Thanks!
Thanks!
Re: General Tuning & Factory Presets (Drive Modes)
you cant change the behavior of the modes through the tune....
my question is: will a modified tune with the T1000 effect the Drive mode settings?
no, like he said, the tunes can not change the drive modes..
I have one more question... this is for 2015 Camaro ZL1 - the preset tunes are 93 oct. and 91 oct..
In Washington State premium gas in 92 octain. So what preset do I use?
Diablo can you make a 92 oct. Tune?
Thanks!
Thanks!
Id use the 91 tune, or load the 93 tune and log it to see how it likes it....
I also have a cold air intake I'm going to install. Are there any custom tunes for that? Any suggestions?
I need to ask, where do I find the spec details for the 2015 Camaro ZL1 tunes? Gas mileage, HP and Torque increases.
http://old.diablosport.com/2015-camaro.htmlklewand wrote:I need to ask, where do I find the spec details for the 2015 Camaro ZL1 tunes? Gas mileage, HP and Torque increases.
if you select i2 or trinity on our site then select your vehicle, and scroll down, you'll see the available tunes and parameters, like this:klewand wrote:I need to ask, where do I find the spec details for the 2015 Camaro ZL1 tunes? Gas mileage, HP and Torque increases.
- 15ZL1.PNG (186.66 KiB) Viewed 5824 times
I recently purchased a Trinity Diablo from a member on the LX Forum and I was able to program everything except the tire size. I'd like to know if there's a limitation on tire size when programming the Trinity? I have a staggered set of 22's (Rear: 295/25/22) if that helps. Thanks!
mikel wrote:if you select i2 or trinity on our site then select your vehicle, and scroll down, you'll see the available tunes and parameters, like this:klewand wrote:I need to ask, where do I find the spec details for the 2015 Camaro ZL1 tunes? Gas mileage, HP and Torque increases.
I'm not able to find that for some reason and when I put my vehicle info up the 7.0L engine (I think that's a Z/28) is the only option I have a 6.2L engine. Please help thank you.
Never-mind I found it... Is there any gas mileage improvement?
