Coolant fans
Dmanw
Coolant fans
Post by Dmanw »
What happened to being able to control the low fan mid fan and high fan? I need this feature back instead of just a desired ECT. How do i get it back? If it's not possible how can I fix the P0128 or something like that, whatever the coolant temp error code is. Any help is greatly appreciated!
DiabloMatt
Re: Coolant fans
Post by DiabloMatt »
what vehicle?
Dmanw
Re: Coolant fans
Post by Dmanw »
DiabloMatt wrote:what vehicle?
2012 charger 3.6. 8 speed and awd if that matters
Re: Coolant fans
Dmanw wrote:What happened to being able to control the low fan mid fan and high fan? I need this feature back instead of just a desired ECT. How do i get it back? If it's not possible how can I fix the P0128 or something like that, whatever the coolant temp error code is. Any help is greatly appreciated!
its not something you can get back, unless you can convince Chrysler to make the fans work that way again ;)
The code is generally caused by a cooler t-stat, post the current last tune written file.
Dmanw
Re: Coolant fans
Post by Dmanw »
I have a 180 t stat i think i failed to mention that. either way below 50 it stays around 172 degrees on the highway no matter what fan temp i use. around town its more responsive to fan temp changes.
I also have a custom tune if that mixes things up.
Dmanw
Re: Coolant fans
Post by Dmanw »
Bump. This is becoming a problem as my oil temp doesn't even get above 165 on the highway which keeps oil pressure around 72 psi when it should be around 40.
Re: Coolant fans
fix attached, this issue will not affect oil temp....
Dmanw
Re: Coolant fans
Post by Dmanw »
mikel wrote:fix attached, this issue will not affect oil temp....
Thank you! I'll try it out this weekend. I'll have to try something else for oil temp.
Dmanw
Re: Coolant fans
Post by Dmanw »
Thanks for the fix its working great! No engine codes!
