Vehicle not supported message
MealMoney
Post by MealMoney »
Just purchased the intune 2, did a wifi update, followed by installing ignition software and update through the software.
Plugged into '12 Challenger 5.7l and went to tune and informed me vehicle not supported and to check for update.
Plugged back into PC and says up to date.
Attached is my info file, any help would be greatly appreciated.
Thank you
info.xml
(1.9 KiB) Downloaded 272 times
Re: Vehicle not supported message
MealMoney wrote:Just purchased the intune 2, did a wifi update, followed by installing ignition software and update through the software.
Thank you
its not asking for an update here, do you have the push button removed and the key inserted to RUN mode?
MealMoney
Post by MealMoney »
Yes I did
MealMoney
Post by MealMoney »
Is there a way to remove the update and start over?
its not seeing the car, make sure its in run mode and that you agree when it asks to check for an update in the vehicle.
MealMoney
Post by MealMoney »
I'll check when I get home again. But I plugged it in, turned ignition clockwise twice to run mode. Hit agree to terms when i2 loaded up. When I hit tune vehicle button in gave me a brief loading screen then followed immediately by vehicle not supported message. Was never any prompt for updating vehicle.
MealMoney
Post by MealMoney »
Still no luck, plugged it in, run more on, saw it checking for vehicle updates but then went to main menu.
I can check vehicle info, trouble codes, but tune car throws up the not supported message.
MealMoney
Post by MealMoney »
Latest info file, seems different, saw a line in it about unsupported calibration ID
info.xml
(1.98 KiB) Downloaded 374 times
MealMoney
Post by MealMoney »
Any thoughts, suggestions?
MealMoney
Post by MealMoney »
Anything more I can do to help I my end?
MealMoney
Post by MealMoney »
Can close this one out, thanks for all the help guys!
