Dyno time
NYESCALADE
Dyno time
I'm going to put my truck on the dyno next Sat. morning....Finally!
I'm going to have some pulls with my exhaust cut-out open and some with it closed.
Any tips to get the most out of it...octane boost, timing etc...?
I already have my LTFT's adjusted to 0.
And I dont have any baseline numbers on a 6.0 AWD, I know it was 345 h.p. stock, but I dont know what the dyno numbers are on a bone stock 6.0. I heard to subtract 20-25% - that puts it at 258-276 h.p. Does that sound right?
2005 GM
U7193, Software 2.10, Hardware 1.10
CAI
Dual 3" Electronic Exhaust cut-outs
CAI
RE: Dyno time
Best bet is to make a pull with the stock tune, then back it up with tuned runs to see the difference.
Make sure you have the best fuel available to you, and monitor knock retard.
Dial in the A/F for peak power if necessary (12.5-12.8:1 ish), and you should be good to go.
RE: Dyno time
BTW, assuming this is an AWD dyno, dont go in expecting big numbers...the only thing that matters is the gains present from the tune.
sickREDsierra
RE: Dyno time
i would bet around 300 rwhp with that 6.0 tuned right.
good luck!
good luck!
2007 Sierra, 370 C.I. , Custom CompCam, ProEdge 3600 converter, 4.11's with eaton LSD, Foose 20's, DynoTune Nitrous, Patriot CNC'd heads
NYESCALADE
RE: Dyno time
O.k sounds good, now on the A/f, should I look for 12.5-12.8 at cruise or at WOT? And if its off what parameter would I adjust on a u7193?
2005 GM
CAI
CAI
Re: RE: Dyno time
No way, not through AWD....sickREDsierra wrote:i would bet around 300 rwhp with that 6.0 tuned right.
good luck!
sickREDsierra
Re: RE: Dyno time
only at WOT, and you would adjust your PEsettings/ fuelNYESCALADE wrote:O.k sounds good, now on the A/f, should I look for 12.5-12.8 at cruise or at WOT? And if its off what parameter would I adjust on a u7193?
sickREDsierra
Re: RE: Dyno time
i still think with the cutouts and CAI, and a good tune, around 300 at the wheels. unless AWD drivetrain loss is that substantial?mikel wrote:No way, not through AWD....sickREDsierra wrote:i would bet around 300 rwhp with that 6.0 tuned right.
good luck!
RE: Re: RE: Dyno time
Yeah, its usually pretty bad....but they come out the hole like a MoFo!
sickREDsierra
did you see that link i posted a while back with the new escalade on 26's AWD running 12's in the 1/4 ??
that mofo was sick!
that mofo was sick!
was it turbo'd?
sickREDsierra
of course!! it was awesome!
Yeah, I think that was the truck from Big3 performance...pretty sick.
2004 4.8L Silverado RCSB
-Custom CAI, 2" - 5" drop
-Flow 40 series 3" in dual 2.5" outs w/ turn downs
-Custom e-fan setup
-All synthetic
-Diablo tune
-160 t-stat
-Doug Thorley Headers.
http://www.myspace.com/dodgesucksfuckingass
-Custom e-fan setup
-All synthetic
-Diablo tune
-160 t-stat
