What is wrong with the Dataviewer???
I have the original predator, I have no problems downloading and installing tunes. I can also log with the predator as well. However, when I open the data and try to record live data it doesn't work. First I have to click on "reconnect to tool", then the screen says, " acquiring vehicle information". This takes about 3 to 5 minutes while it starts at 1% and slowly climbs to 100%. After this ,still no luck. I try to expand the "PID" tree but it wont allow me to expand it. The only thing I'm able to do is download a log from the handheld and view it that way. I've tried a new cable, and three different laptops all with the same result. Any ideas???
- screenshot.jpg (897.93 KiB) Viewed 6574 times
Re: What is wrong with the Dataviewer???
what tool and version on the tool?
Which version of DV?
I'm running an original Predator with version "v.9r22" and the most up to date version of the Dataviewer "3.4.3.1" Thank you for the help...
- Predator-1.jpg (869.94 KiB) Viewed 6564 times
I am really not sure. Honestly haven't tried using a Pred with DV in years, its possible something may have broken there.
Might be a great time to upgrade to a newer device.
Has anyone found a fix to this issue, mine is doing the same thing
thanks
thanks
uninstall dv then try installing this one.
- DataViewer_3.3.0.15.exe
- (19.58 MiB) Downloaded 556 times
that solved it, thanks for the fast response and support
