intune analog ports not appearing in dataviewer
fixit
Post by fixit »
i've configured the intune (updated today), 2 analog ports (afr and oil) but they don't show up under the dataview external tab..
attached
info.xml
screenshot of dataview
thank you
steve
Re: intune analog ports not appearing in dataviewer
load this to the i3 then run the log again.
fixit
Post by fixit »
Hi Mike
failed.. current firmware 1r03m cannot be replaced by ....
screen shot attached.
Thank you
Steve
OK, thats because you are using an i1000, not the i2/i3 like the section of the forum would indicate :)
That said, you seem to have an old version and you should update the i1 with update agent and see if that helps.
fixit
Post by fixit »
sorry about that...
updated it yesterday still doesn't work, here is the info.xml
its not up to date....way behind honestly.
try again, make sure theres not a group update sitting in the drive.
fixit
Post by fixit »
deleted the group file in the "g:" drive, rebooted and tried again but failed.. no group_update file but its still complaining about one..
also tired on the device, settings, advanced, clear all updates -- response "clear all updates done".. same problem
screen shots
thank you
steve
see if it will import this file.
fixit
Post by fixit »
mike, it worked!
(after applying fix rebooted a couple of times and then i used to update agent.. )
thank you!
good deal, enjoy.
