predator won't back up original memory
hi , i tried to install the predator and followed instructions but came up saying it did not see ignition, maybe a performance module installed,and original back up not saved. showing codes p0602, p0605, p1211,p1690.
please tell me what i need to do.
keith
jamaica
keith
jamaica
predator
hi, i purchased this truck used and this is the first time i am trying anything like this.i will be checking if there is any chip plugged in the computer, but if not what can i do?
2000 ford f250 , serial# doo4c2d, V9R01,calid VOAA8R4
Keith
Keith
RE: predator
Call support on Monday, someone will need to look up the codes and step you through the install.
johnc <at> diablosport.com
RE: predator
These are not active codes, the Predator is simply stating that those codes are normal for a tuned vehicle...
2000 ford f250- Predator Problems
Hi, i just removed the computer box and there is no chip plugged into it,
please let me know what is my next step.
thanks again guys,
Keith
thanks again guys,
Keith
RE: 2000 ford f250- Predator Problems
OK, try this.
Go to options/troubleshooting/verification.
Turn verification off, then attempt to install the tune, let me know if that works...
hI ,I Tried that and then attempted to install but came back with the same results,any other things i can try?
thanks
keith
Jamaica
thanks
keith
Jamaica
If it would not save it with Verification off, then I do not know what it could be.
Best suggestion I can make now is to have the truck reflashed at a Ford dealer.
Is there anything i can try before sending this Predator back as you know i am in jamaica. i have gotten another computer and it still reads as above, what could the problem be. I purchased this unit from Extreme Diesel online.
thanks
Keith
thanks
Keith
Short of having the PCM reflashed by a Fprd dealer, I do not have any other suggestions at this point.
ok i will have it reflashed and will let you know what happens
hey guys i finally got the predater to work one problem can this tool be used to change the speed limit settings and how do i do it.Speed limiter trips at 87mph.
thanks again
Keith
thanks again
Keith
Before you install the tune ..you have the option to modify parameters.select modify parameters.. then you should see another menu...select speed limiter.Hope this helps.
2001 f250 CCSB 4WD 5"Exhaust,
BallBuster Turbo,ITP Regulated Return,03 Headlights
CCV-MOD,,AIH Delete,Built-Trans,Programmer,DIY Intake,EBPV delete,Boost-fooler,Gauges,305's
i did some fiddling around and then test drive now its going up to 100mph + its awesome.
Thanks all
Thanks all
