timing
hodge9386
timing
Post by hodge9386 »
on my 03 silverado with the 5.3 how much can i advance the timing safely, and when will i know if its right
RE: timing
the timing adjustment is only for WOT...
you'll need to log for KR... if there is any, then you'll need to back-off the timing...
hodge9386
RE: timing
Post by hodge9386 »
so i need to adjust it and then log. do u know what the timing should be for max performance
RE: timing
4% is roughly equal to 1* of timing...
which tune are you using, and what octane gas??
and to be honest with ya, I don't ever increase the timing on their diablo tunes... it's already pretty maxed out as is in the canned tunes... when I do custom tunes for people, I actually end up pulling out some timing to cure minor KR issues they have, and they end up getting more power due to no KR and no timing being pulled by the ecm...
hodge9386
RE: timing
Post by hodge9386 »
im using the diablo tune with 93 octane gas, i went to the track and lowered my time by a half a sec off the diablo tune by increasing my timing 6*, i think its degrees, but i ran out of time and didnt get to see how far i could push it
05Z71
RE: timing
Post by 05Z71 »
AAAAAAAAANNNNNNNNDDDDDDDDDDD................................BOOM!!!!! :drivingbad:
Makin friends one post at a time!
05 Chevy Z71 5.3L, 18x9 KMC XD Spy Wheels, 275/70R18 Cooper Zeon LTZ, Cherry Bomb Exhaust, K&N Drop in, Predator TWEAKED
hodge9386
RE: timing
Post by hodge9386 »
it runs 28* at wot with no knock, is that bad
jrmybck
RE: timing
Post by jrmybck »
these trucks run like 40* not 28
AKAssasain
RE: timing
Post by AKAssasain »
mine is at 41* no knock, even if i lug.
RE: timing
yes, correct... that's at normal part-throttle driving...
it's not that high at WOT though, heh...
RE: timing
WOT vs part throttle timing are totally different worlds.
jrmybck
RE: timing
Post by jrmybck »
how much timing should they have at wot. a 350 small block is 32-36
