U7135 Is shift firmness increased in the Performance Tunes?
Searched but couldn't find an answer.
I'm assuming it is....
TIA!
Matt
TIA!
Matt
RE: U7135 Is shift firmness increased in the Performance Tun
Mine kicks like a muel going from 1st to 2nd with the 6.1l...so I guess so? What exactly is "shift firmness"? I could be mistaking it, it's very on time...just rough.
6.1, yes, 5.7, no....
Re: RE: U7135 Is shift firmness increased in the Performance
Thanks!mikel wrote:6.1, yes, 5.7, no....
I've got an R/T (5.7). Can I modify the firmness in the performance tune?
RE: Re: RE: U7135 Is shift firmness increased in the Perform
Yes, under quick adjust.
Re: RE: Re: RE: U7135 Is shift firmness increased in the Per
I can't find this, all I see is raised\stock shift points...mikel wrote:Yes, under quick adjust.
I'll try later and report back....RPaulG87 wrote:I can't find this, all I see is raised\stock shift points...mikel wrote:Yes, under quick adjust.
I did some research and apparently it's under "stock tune modify" so I don't know if that even effects it if you're using a diablo tune :-\nagelm123 wrote:I'll try later and report back....RPaulG87 wrote:I can't find this, all I see is raised\stock shift points...mikel wrote:Yes, under quick adjust.
RE: Re: RE: Re: RE: U7135 Is shift firmness increased in the
No, it is in the Quick Adjust menu, you dont want tomodify the stock tune.
Re: RE: Re: RE: Re: RE: U7135 Is shift firmness increased in
Could you show me where shift firmness is then, because I can't find it I just went down to plug it in and check, I see axle, shift points, dyno, and tire size...that's all under quick adjust...and under shift points it's raised or stock, no firmness setting :-\mikel wrote:No, it is in the Quick Adjust menu, you dont want tomodify the stock tune.
RE: Re: RE: Re: RE: Re: RE: U7135 Is shift firmness increase
what is your calibration ID?
Re: RE: Re: RE: Re: RE: Re: RE: U7135 Is shift firmness incr
I'll have to find that out next time I go out, what would that change? I originally used this on a 300c SRT-8 (2008) and reflashed it to 9r27 for the Challenger...does the 91 octane perf tune change firm shiftness? if it does then that would explain the kick I get now going from 1st to 2nd which causes the tires to bark..mikel wrote:what is your calibration ID?
Easy...nagelm123 wrote:I'll try later and report back....RPaulG87 wrote:I can't find this, all I see is raised\stock shift points...mikel wrote:Yes, under quick adjust.
Go to Performance Tunes
You will have to accept, then turn key on, continue
Then to Quick Adjust
Then to Transmission and then you'll see it.
Yeah mine doesn't have that option :-\nagelm123 wrote:Easy...nagelm123 wrote:I'll try later and report back....RPaulG87 wrote: I can't find this, all I see is raised\stock shift points...
OK from what I've gathered SHIFT firmness is not available on 6.1l models..why is this? :-\
