Throttle lag
LeHemi
Throttle lag
Post by LeHemi »
I have a 7137 on a 2010 ram hemi and just curious as to if this tune rewrite is different from the throttle sensitivity adjustment in the canned tune?
RE: Throttle lag
If you are seeing that adjustable parameter, yes. We change this in the tunes already, but there is room for more sensitivity if you desire.
LeHemi
Throttle response
Post by LeHemi »
I think I have attached the last tune written, would you please send me the file with more throttle sensitivity and also check to see if you can take out any more torque management.
PCM_05187935AD_Perf_93oct_modified.drg
(5.25 KiB) Downloaded 268 times
LeHemi
RE: Throttle response
Post by LeHemi »
Hey Mike, were you able to do anything about my request?
Have you tried adjusting it yourself?
You have the parameter, no need to be loading tunes.....
white_lightning
Re: RE: Re: RE: Throttle lag
Post by white_lightning »
silverdaytona wrote:Tried to load the files you sent me yesterday, again this morning and the message it gave me was Problem with Custom Tune 05094258ad wont be used. ad is the trans part of the tune.
you ever get the trans tune to load? I have an '05 truck too, and have been able to load custom trans tunes. there are a couple tricks to getting a custom trans tune to load in an '05.
silverdaytona
RE: Re: RE: Re: RE: Throttle lag
Post by silverdaytona »
No,I just loaded the PCM part and that worked pretty damn good. What are the couple of tricks that you are talking about?
white_lightning
Re: RE: Re: RE: Re: RE: Throttle lag
silverdaytona wrote:No,I just loaded the PCM part and that worked pretty damn good. What are the couple of tricks that you are talking about?
I will PM you about the tricks.
MG7
Throttle response increase
Post by MG7 »
I just purchased a predtor u7136 for my 07 charger sxt. i am currently running revision v.9r06. can you please modify my last written tune to increase my throttle response. thanks alot.
PCM_05094911AI_Perf_93oct.drg
(4.25 KiB) Downloaded 219 times
MG7
Post by MG7 »
bump
MOPRWGN
Post by MOPRWGN »
I also would like to get rid of my throttle lag. I have a Predator u7136 for my 05 3.5L 4 speed magnum. I run the 91 tune with the 9r01 since i got it way back then. How would i go about doing this? At first when i reload the 91 tune it seems to run great but act like it goes back to a stock tune so every month i go back to stock and reload the 91 tune just so it feels like it not a stock feeling.
Hope this makes some sense
Thanks.
MG7
Post by MG7 »
mikel wrote:there is already an increase in response in the canned tunes, if you want more, export and post your last tune written.
I just purchased a predtor u7136 for my 07 charger sxt. i am currently running revision v.9r06. I am currently not abke to adjust throttle sensitivity. Attached is my last written tune. can you please modify my last written tune to increase my throttle response. thanks alot.
(4.25 KiB) Downloaded 285 times
here you go
pcm_05094911ai_throttle.drg
(64.63 KiB) Downloaded 206 times
fradaj
Post by fradaj »
I just purchased a Predator u7136 for a 2010 Challenger SE. Attached is my last written tune. Can you please modify my last written tune to increase my throttle response. Thanks alot.
68054123AC_custom.drg
(3.25 KiB) Downloaded 233 times
alan777
Post by alan777 »
what do you need to fix my throttle responce. i have a 7135 with perf.91 tune and i have the mds shut off,that it,no other changes it is a challenger 5.7 auto 2010 with flowmaster exhaust ,all stock.
throttle feels washy. and shifts 1-2 and 2-3 toooo soon, even under a load. sounds and feels like a dog. can you help?
hope you can help,.
