AEV tune
julan
AEV tune
Post by julan »
Hi,
I have 2007 wrangler with 6.4 engine swap and AEV PCM. I need to tune the car, please advice.
Note: The customer has the original PCM and 5.7 as well, I do have an access to witech (dealer device) so that would help if we need it.
julan
Re: AEV tune
Post by julan »
please move it to dealer section, thnx
Re: AEV tune
Have you tried plugging into the AEV PCM yet?
What PCM is it?
if it asks for a cal update, stop and unplug it, otherwise you will render the car undriveable.
julan
Re: AEV tune
Post by julan »
no i didn't , because i ran to this case before :D
Please advice how can we tune it...
Re: AEV tune
if it asks for a cal update you simply cant tune it.
julan
Re: AEV tune
Post by julan »
what if i work on the original PCM, can we do it? I mean have it from 6cyl to 8 cylinders 6.4?
Re: AEV tune
no, that wont work.
jwdemon
Re: AEV tune
Post by jwdemon »
5.7 is not a 6 cylinder, it's a v8.
julan
Re: AEV tune
Post by julan »
Then how can we do it?
Re: AEV tune
Maybe I am not being clear enough.
If it asks for a cal update, you can not tune it.
They have edited that pcm to work outside the vehicle it was intended for, and if you update the pcm, you erase those changes and render the vehicle useless.
Only way to tune it is if the cal they load is directly supported by the tool.
To this point, you have not even confirmed if the tool asks for a cal update or not.
julan
Re: AEV tune
Post by julan »
it did ask for an update
Re: AEV tune
not tuneable then....try B&G :)
the black tide
Re: AEV tune
Post by the black tide »
mikel wrote:not tuneable then....try B&G :)
can't he get a 6.4 base file to tune it?
if not i think he can tune it only with 6.4 pcm, right?
Re: AEV tune
there is more to it than that.....its a swap issue with disabling security.
julan
Re: AEV tune
Post by julan »
hey,
I got the binary file of the AEV tune, can you add suport to it?
