AEV tune
AEV tune
Hi,
I have 2007 wrangler with 6.4 engine swap and AEV PCM. I need to tune the car, please advice.
Note: The customer has the original PCM and 5.7 as well, I do have an access to witech (dealer device) so that would help if we need it.
Re: AEV tune
Have you tried plugging into the AEV PCM yet?
What PCM is it?
if it asks for a cal update, stop and unplug it, otherwise you will render the car undriveable.
What PCM is it?
Re: AEV tune
no i didn't , because i ran to this case before
Please advice how can we tune it...
Re: AEV tune
if it asks for a cal update you simply cant tune it.
Re: AEV tune
what if i work on the original PCM, can we do it? I mean have it from 6cyl to 8 cylinders 6.4?
Re: AEV tune
no, that wont work.
Re: AEV tune
5.7 is not a 6 cylinder, it's a v8.
Re: AEV tune
Maybe I am not being clear enough.
If it asks for a cal update, you can not tune it.
They have edited that pcm to work outside the vehicle it was intended for, and if you update the pcm, you erase those changes and render the vehicle useless.
Only way to tune it is if the cal they load is directly supported by the tool.
To this point, you have not even confirmed if the tool asks for a cal update or not.
Re: AEV tune
not tuneable then....try B&G
the black tide
Re: AEV tune
can't he get a 6.4 base file to tune it?mikel wrote:not tuneable then....try B&G
if not i think he can tune it only with 6.4 pcm, right?
Re: AEV tune
there is more to it than that.....its a swap issue with disabling security.
Re: AEV tune
hey,
I got the binary file of the AEV tune, can you add suport to it?
