2014 Silverado Quick shifting
selmahotrod
My 2014 Silverado 1500 4X4 is shifting into high gear way to fast and causing me to have to push the excellerator down a lot to pick up speed. I have tried to adjust all the settings on my Trinity to no avail. I also have turned the DOD off and that helped very little. I have the 5.3L with 3.42 gears, standard tires and wheels, Flowmaster exhaust and a CAI. Can anyone give me any sugestions? Thanks, Mark
Re: 2014 Silverado Quick shifting
are you adding throttle boost?
selmahotrod
I removed throttle boost and that helped some. I put truck back to stock and it shifts ok again. All I seem to be able to use my Trinity for is to deactivate DOD and speed limiter, that sucks!
you dont notice better power, reduced TM, better shifting, and better throttle response??selmahotrod wrote:I removed throttle boost and that helped some. I put truck back to stock and it shifts ok again. All I seem to be able to use my Trinity for is to deactivate DOD and speed limiter, that sucks!
We'll sort out the early shifting stuff....
selmahotrod
Yes, it does all that but the quick shift is worse with it programed. It needs some retuneing with a new update.
OK, we're looking into it.
selmahotrod
Great! I hope you can come up with a new update. Thanks, Mark
selmahotrod
Just bought an Edge CTS, works perfect for my 2014 Silverado. Anyone want to buy a Trinity T 1000? Cheap!
I have a 14 Silverado as well with AirAid CAI, Jet throttle body and MAF sensor. I added a Borla ATAK system and tuned the 87 canned tune, DOD off and adjusted the throttle response to 17%. The shifting was horrible, if I don't floor it. Going 2 - 3 the engine has to catch up and basically lags really bad. I tuned the trottle back to stock and will see how it goes....
Ps. How about getting an auto update tool for MAC?
I would get rid of the jet throttle body and aftermarket MAF sensor.. bad bad bad.. Aftermarket MAF sensors do not report true, correct information to the pcm... aftermarket MAF sensor calibrations fool the pcm into thinking the engine is running leaner than it really is, so when trying to tune it and adjust the fueling correctly, it will never really be right/correct, because that aftermarket MAF sensor is not reporting true/accurate info to begin with... Plus, they usually cause idle and driveability issues.. once you put your stock GM MAF sensor back on, I'm sure you'll notice it idles and drives much smoother...
Plus, the stock GM MAF sensors are good for 550/600+ hp anyway, so there is no reason to change it... So put the stock GM MAF sensor back on... If you don't have it anymore, then get one...
and I wouldn't put anything jet on a tricycle..
After returning to stock throttle the truck is running great. Shifting is nearly perfect.
