2017 GMC 6.2l 8sp
whoodie22
Re: 2017 GMC 6.2l 8sp
Post by whoodie22 »
Any word on what to do when my Itune is just stuck trying to read the ECM?
whoodie22 wrote:Any word on what to do when my Itune is just stuck trying to read the ECM?
did it already prompt you to go to the PC and update using ignition?
ignition in RUN mode?
whoodie22
Post by whoodie22 »
Yes, it did tell me put key in run position. Then it ask read PCM i say yes then it gets stuck in read mode. It has asked read PCM i hit yes then it ask read TCM and I click no, then it just sits please wait trying to read.
whoodie22 wrote:Yes, it did tell me put key in run position. Then it ask read PCM i say yes then it gets stuck in read mode. It has asked read PCM i hit yes then it ask read TCM and I click no, then it just sits please wait trying to read.
can you post the current info.xml file and anything in the runtime folder on the i2 drive so we can sort this out?
whoodie22
Post by whoodie22 »
Where do I find these files? I looked in the settings and under the ? tab and can't find the info.xml file or runtime folder.
whoodie22 wrote:Where do I find these files? I looked in the settings and under the ? tab and can't find the info.xml file or runtime folder.
they are in the drive called i2 on the pc.
whoodie22
Post by whoodie22 »
<?xml version="1.0"?>
-<tool_info>
<registration updates="0" tool_oem="DIABLO_G" status="0" sn="14U7ZAVXER"/>
-<applications count="5">
<application rev="2r01t" name="vehicle"/>
<application rev="missing" name="updater"/>
<application rev="2r01l" name="gui"/>
<application rev="missing" name="installer"/>
<application rev="2r01a" name="logger"/>
</applications>
-<databases gui="2r01g" vin="2r01h" dtc="2r01a" dbnames="2r00">
<database pid="2r01cc" mfr="DCX"/>
<database pid="2r01cf" mfr="FORD"/>
<database pid="2r01ba" mfr="GM" tune="2t02zt"/>
</databases>
-<system rev="1r01a" config="1r01d">
<option name="Wifi" enabled="false"/>
</system>
<last-connected vin="3GTU2NEJ3HG194637" mfr="GM" calid="12677878, 12678704, 12678681, 12667480, 12667660, 12667714, 12667806, 12679747"/>
<last-connected calid="24283721, 24283176, 24283173, 24272181, 24274482, 24283178"/>
<licenses tuned="0" available="1"/>
<update request="true"/>
<reg reg="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"/>
</tool_info>
whoodie22
Post by whoodie22 »
The runtime folder has 24 files in it but I can't copy and paste them nor drag them over. I tried opening them and it says Windows can't open this file.
Zach
Post by Zach »
whoodie22 wrote:The runtime folder has 24 files in it but I can't copy and paste them nor drag them over. I tried opening them and it says Windows can't open this file.
please email them to zhill <@> powerteq.com
whoodie22
Post by whoodie22 »
It is on the way now.
From Jason Starks
whoodie22
Post by whoodie22 »
Did you receive my email? Just want to make sure you got it not rushing.
canyou attach the info.xml file from the i2 drive here so we can check it out?
use the attach file option below when you are replying here.
whoodie22
Post by whoodie22 »
I attached it to the email as well.
whoodie22
Post by whoodie22 »
mikel wrote:canyou attach the info.xml file from the i2 drive here so we can check it out?
whoodie22
Post by whoodie22 »
Any update on this?
