6.4 LTFT STFT dilemma
ahmy501
Post by ahmy501 »
I have a JEEP TJ AVE brute with a stroked 6.1 to 6.4 Arrington the wire harness and the ecu is from Hotwire the car has been running rough since I bought it I have run several diagnosis on the engine all I found is nothing that concerns/impacts engine health, checked the Engine for air leaks non found also replaced a new fuel pump unit with the assembly, I'm almost certain that my issue is related to an ecu proper tuning i just need someone to look @ my log files and determine weather its a tune related issue or mechanical issue.
I ran a diag scan no trouble codes related to engine`s health i have SKIM DTC and transmission gear ratio being incorrect + Fuel level sensor, Yes i could smell fuel i also noticed "THR POSN" not working and DELTHR PID is working fine not sure if that could be an issue.
Your help is appreciated
TJ Brute Logs.rar
(763.48 KiB) Downloaded 328 times
Re: 6.4 LTFT STFT dilemma
was it custom tuned for the 392 or is it running a standard 6.1 file?
ahmy501
Post by ahmy501 »
mikel wrote:was it custom tuned for the 392 or is it running a standard 6.1 file?
The pcm is MY05 custom tuned
ahmy501
Post by ahmy501 »
After going through the logs i noticed that when the truck goes @ WOT the AFR gets @ 11.12/13.70 the LTFT STFT get smoother and almost perfect closer to 0. please check my log labled " Highway driving part 1"
Strangely enough on the "Coldstart log" some injectors stop working noticed that takes place when AFR is @ 14:41 both STFL 1/2 are happy with a value of 0. please check the attached images.
cold start 3x injectors PW CYL 0.0 2.JPG (109.44 KiB) Viewed 3415 times
cold start 3x injectors PW CYL 0.0.JPG (124.22 KiB) Viewed 3415 times
ronaldMem
6 4 LTFT STFT dilemma
Post by ronaldMem »
Hi,
While tuning idle and close above I noticed that AFR was slightly rich of target and STFT was correcting by removing fuel but simultaneously LTFT kept adding fuel.
Am I missing something here or is it a bug?
