Predator u7135 9r27 with 300c 5.7 hemi -05
Thorvald
Post by Thorvald »
Hello there,
I'm total noobie with these tuning stuff and I bought just 300c hemi.
There was predator with it and there's 93oct CAI tuning in.
I have read that there should be options for 91 too and throttle control and stuff but that predator has only that 93 tune.
There was no cords with it or any discs, can I use usbcable from the local store to use it or do I have to order one from here?
Should I update to 9r30? Does it work on 05 300 hemi? And does it have throttle control and 91oct tunes etc.
And my car gives acode p2096 and I think that was some O2 sensor code for going too lean and getting too much air, they told me that it's because filter and that tuning? Is it really so? I cleared the code and now its away but lets see when it appears again.
I'm really confused :shock: :lol:
Thanks for your answer already
I'm too old for these computer stuff :lol:
Re: Predator u7135 9r27 with 300c 5.7 hemi -05
export models did not get 91 octane tunes.
There is throttle boost adjustment in there.
Let us know if the code comes back.
Thorvald
Post by Thorvald »
Thanks for fast answer.
Why export models don't have that? It's our 95oct what is, atleast I think most used gas in here. :)
Is it possible to load to my predator?
Throttle boost is in this? Okay, have to do some research more then...
Yes, I will do that.. I think I'm going to buy bluetooth obd and watch there if those sensor are okay by voltage or are some broken.
So there would be no need at all to update?
Is it possible to put stock tune in and then adjust throttles sensitivity? I'm already thinking about coming winter. :lol:
Thank you very much again.
Thorvald
Post by Thorvald »
mikel wrote:export models did not get 91 octane tunes.
Yeah, the code came back after 30km. It doesn't effect in consumption or anything.. weird.
And I didn't found any throttle adjust. Only idle, wot,transmission,tire size, mds and dyno.
what version is on the tuner currently?
Thorvald
Post by Thorvald »
mikel wrote:what version is on the tuner currently?
It's 9r27
hmm, throttle boost really should be there. Can you double check?
Thorvald
Post by Thorvald »
mikel wrote:hmm, throttle boost really should be there. Can you double check?
Checked and didn't found it :oops:
What menus i should go ,where that throttle boost should be found?
Thorvald
Post by Thorvald »
These is all i found and that version
Thorvald
Post by Thorvald »
Is there any solution to this?
What does mean that star next to MDS?
try loading 9r30
u7135-9r30.crom
(1.18 MiB) Downloaded 551 times
Thorvald
Post by Thorvald »
Okey, i will try that when i get my cable.
I think i should put the stock tune back to my car before update?
Does the update work, that i just put it with usb to computer and put the file in or do i have to load something to my computer first?
Is it possible to get that 91oct tune and 91oct CAI too to my predator? Would be useful.
yes, you have to restore the original backup stock tune to the car first... it won't let you update if you don't.
Return to “General Support”
