I'm in the middle installing a full Stainless Works exhaust on 19 Camaro SS that comes without the mid AFM valves.
I have used the Diablosport I3 Platinum to program disable of AFM.
My question is;
Can I physically remove the GM exhaust AFM valve unit and plug the end of the electrical connector without getting a dash error code ?
Thanks for replies
Hary
Delete Of AFM Valves After Tune Q?
Re: Delete Of AFM Valves After Tune Q?
that will likely lead to a code, not housed in the pcm, making it tough to disable. Might be some simulators out there that plug in to mimic the factory valves and avoid codes.
Hary Gahtoe
So it means; I still have to connect the factory valve units to prevent error codes even though there are no actuater valves in the pipes ?
I can do that, although it does seem counter productive.
Next question then;
If this is my only option where do I look for a plug-in simulator?
I'm open to any clues or followup.
Hary
Next question then;
Hary
Hary Gahtoe
Something like this ?
exactly.
Hary Gahtoe
So the "muffler valve simulators" Will stop an error code.
Mikel reply;
"exactly"
Thank you. Much appreciated.
Hary Gahtoe
Mikel reply;
"exactly"
Hary Gahtoe
Hary Gahtoe
Have the simulator plugs installed and after a month still have error code after 3 deletes
could be a different issue. whats the code exactly?
